Results 1 to 8 of 8
Thread: Sub-microsecond delay on Teensy 4
    Jul 2020
    2
    I'm trying to implement a simple software SPI for the Teensy 4.0 and I am looking for a way to get a very short delay of at least 25ns but optimally less than 100ns with something similar to delayMicroseconds. Is this possible, or is there a better software SPI solution already available.
    I can't use the hardware SPI pins because of the way my project is already laid out.
    22,756
    delayNanoseconds(25);
    Jul 2020
    2
    D'oh! Should have looked around before I posted. That's exactly what I need.
    Thank you!
    Which library includes it?
    12,406
    Teensy 4.x with the 1062 processor - installed with TeensyDuino.
    Is there a version of delayNanoseconds for Teensy 3.2?
    I thought maybe using a Pit?
    12,406
    The same code for T_4.x would generally work on T_3.x's { with F_CPU_ACTUAL changed to F_CPU }. The CycleCounter may need to be started if not in use, it is started before setup on the T_4.x's. The results and resolution would be a bit less with the clock speed differential.
    see:: ...\hardware\teensy\avr\cores\teensy4\core_pins.h
    May 2015
    USA
    647
