Hi Folks
I am building a wireless Midi controller (musical instrument) with a variety of sensors intended to trigger Midi notes and CC values.
Ignoring the later processes for now (eg Midi stuff) my current challenge is deciding what architecture to use for the ADC stages, and was hoping someone could advise. I have at least settled on using one (or more) Teensy 3.# / 4.# as microcontroller.
Pertinent spec:
• 50 Analog Inputs needed (mostly from FSR type sensors).
• 10-bit resolution needed on all (will convert to 7-bit further down the line for Midi, but need 10-bits to allow for response processing first).
• Lowest possible latency (sub 3ms, hopefully much lower).
• Sample Rate – ideally no lower than 10kHz for each ‘channel’ / input.
• Power consumption – will be powered using rechargeable 5v/12000mAh battery packs. Need to get a sensible amount of usage time out of a fully charged battery (eg no less than 1 hour, ideally much more).
• Sampled data is to stream wirelessly using nRF2401 module to a separate receiving module (USB connected to PC). I am considering a second onboard microcontroller for the transmitter, partly because there will also be an OLED screen to drive on the device, and maybe data to receive back from the USB module as well (to display on the OLED screen), and the first Teensy may be 100% occupied just sampling data.
• Space on board the device should not be an issue. I have room for 2 maybe 3 teensys and other circuit boards for external chips, input signal pre-processing etc as may be needed.
As the maximum Teensy Analog input count is 24, my need for 50 immediately means I’ll need something extra.
I have looked at external ADC chips, which I am happy to use if they will do what I need, but there is a huge range available and I can’t get much confidence that they will work with a Teensy as needed, and crucially that my limited programming knowledge will enable me to get them working as needed. I have also concluded I will likely need op-amp buffers in front of each ADC input, sometimes just to get the signal at the right level/range, but also I understand without buffers there are impedance issues that start to play havoc with fast multichannel sampling (something to do with the time to charge the capacitors in the ADCs). I mention this because I understand some ADC chips include such buffers integrated into the chip, which sounds tidy if appropriate.
Alternatively I think I could use multiplexer(s) to expand the input count for the on-board Teensy analog inputs. Again I have no experience of these.
Ideally what I would appreciate is some advice as to which option is likely to perform best to my needs AND be most manageable for me to implement.
Also suggestions of specific Chips and how to implement (eg which libraries might support, how to connect etc) would be much appreciated.
Any comments on using two Teensys (ie a separate one to transmit the data), including how to connect the two, would also be welcome.
Hopefully that's all the pertinent info without drowning readers in the rest, but will provide anything more if needed.
Many thanks for reading.
Pertinent spec:
