Results 1 to 6 of 6
Thread: Ethernet lwip Boards.txt hack? where is it documented?
    Mar 2016
    170
    I overwrote my boards.txt file and lost the "hack". For the life of me, I can't find the readme that describes what to do. Could some kind soul point me in the right direction?
    Mar 2016
    170
    Hmmm, is it supposed to be in the readme.txt here - https://github.com/PaulStoffregen/te...aster/t41ether
    There is a note that says "adjust include paths for Arduino" for the README.TXT but nothing in the readme. There is this in the readme:
    but the link gives me a permission error.
    11,943
    Is it this:
    Added this for this machine to boards.txt: teensy41.build.flags.common=-g -Wall -ffunction-sections -fdata-sections -nostdlib -IT:\tCode\libraries\lwip\src\include
    replace "tCode" with personal sketchbook folder name and the drive letter instead of "T:"
    Mar 2016
    170
    Thank you.
    I'm trying to build lwip_websrv the T4.1 under TD 1.53. I built it successfully under an earlier TD version (1.51, iirc) but am getting this error:
    lwip_websrv:191: error: cannot convert 'uint8_t* {aka unsigned char*}' to 'ip_addr_t* {aka ip4_addr*}' for argument '2' to 'void enet_init(ip_addr_t*, ip_addr_t*, ip_addr_t*)'
    enet_init(PHY_ADDR, mac, &ip, &mask, &gateway);
    Using library lwip at version 2.0.2 in folder: D:\Documents\Arduino\libraries\lwip
    I thought it was the hack problem but I edited boards.txt with the change and still get the error. maybe it's something else? It looks like there are the wrong number of arguments to enet_init based on lwip_t41.h.
    My sketch folder is d:\Documents\Arduino.
    Boards.txt entry is now
    teensy41.build.flags.common=-g -Wall -ffunction-sections -fdata-sections -nostdlib -ID:\Documents\Arduino\libraries\lwip\src\include
    I can see the arduino IDE using the that in the command line and can open files in the lwip directory via that path so it's a correct path.
    11,943
    seems the file locations were migrated ... maybe something else.
    2,558
    ddrown refactored the lwip include files so boards.txt no longer needs to be modified. As you noted, he also changed (cleaned up) enet_init()
    visit https://github.com/ddrown/teensy41_ethernet and see examples/ also see https://forum.pjrc.com/threads/61581...4-1-NTP-server
    you might also like the Arduino Ethernet API for the T4.1 native ethernet, https://forum.pjrc.com/threads/60857...hernet-Library
