Glitch when Playing Audio from SD card in Teensy 3.2
ajay.dusa
When Playing Audio from SD card through Teensy 3.2. I am getting Glitch in between at random intervals and it is happening in all audio files. Initially I thought, the problem would be in my WAV audio file. But the file is clean. I recorded the Audio using Audacity to see the comparison between the played audio from Teensy 3.2 and WAV file which I loaded onto SD card.
For Testing purpose I am using WavFilePlayerUSB.ino code. I have added the screenshot of the comparison and link for the audio file where I am getting the glitch.
https://drive.google.com/file/d/12boHFJwzo2XSV-vXT5HExOy6XyafSjFG/view?usp=sharing
Finally, the Problem is solved. Issue was with the SD Card. I was using SanDisk 8GB Class 4 MicroSD card I replaced it with the Samsung Evo 16GB Class 10. There were No Glitches Nothing.
