https://en.reddit.com/r/arduino/comm..._clock_cycles/
Timer0 interrupts every millisecond and may cause jitter in your timer1 measurement. Timer0 is used for millis() and micros()
you can also look at the assembler code the compiler generates (.lst).
a simple TIMER1 cycle counting sketch
// cycle counter using timer 1
volatile unsigned int t1, t2;
unsigned long result;
unsigned int i, mint, maxt;
Serial.begin(9600); while (!Serial);
TCCR1A = 0;// set registers to 0
TCCR1B = 0;
TCCR1C = 0;
TCNT1 = 0;
TCCR1B = 1;// start timer 1
TCCR1B = 0; //stop the timer
t2 = TCNT1; //store passed ticks
Serial.print("res ");
Serial.println(t2);
TCNT1 = 0;
asm volatile("nop");
Serial.print("4 nops ");
Serial.println(t2);
TCNT1 = 0;
result = millis();
Serial.print("millis ");
Serial.println(t2);
analogRead(A0);
analogRead(A0);
TCNT1 = 0;
i = analogRead(A0);
Serial.print("ADC ");
Serial.println(t2);
void loop() {}
TCNT1 = 0;
25e: 10 92 85 00 sts 0x0085, r1 ; 0x800085 <__TEXT_REGION_LENGTH__+0x7e0085>
262: 10 92 84 00 sts 0x0084, r1 ; 0x800084 <__TEXT_REGION_LENGTH__+0x7e0084>
266: c0 93 81 00 sts 0x0081, r28 ; 0x800081 <__TEXT_REGION_LENGTH__+0x7e0081>
272: 10 92 81 00 sts 0x0081, r1 ; 0x800081 <__TEXT_REGION_LENGTH__+0x7e0081>
276: 80 91 84 00 lds r24, 0x0084 ; 0x800084 <__TEXT_REGION_LENGTH__+0x7e0084>
27a: 90 91 85 00 lds r25, 0x0085 ; 0x800085 <__TEXT_REGION_LENGTH__+0x7e0085>
