Senior Member+
Yes, I like it too.
For SDRs and such a test of massive overclocked ADCs would be helpful
Originally Posted by
PaulS
In case you're interested; I did a bunch of measurements on several DAC's. See
this thread.
The PCM5102A is my favorite from a cost vs quality perspective.
Paul
I'd add a caution here: audio DACs and ADCs typically don't have accurate voltage levels, for instance the gain error on the PCM5102A
is worst-case +/- 6% (+/- 0.5dB). This would be a show-stopper for any precision DC control uses, for instance.
Audio ADCs and DACs are designed for ac signals where gain stability of 0.5dB or so isn't considered an issue, whereas for data
acquisition or control purposes you typically want your gain accuracy to match your voltage reference performance.
- You may not post replies
- You may not edit your posts
Forum Rules
