Results 1 to 7 of 7
Thread: Teensy 4.1 DAC Output
    Dec 2016
    13
    Hi everyone,
    was amazed to see that there is a teensy 4.1 with similar pinout as the 3.5/3.6. But after byuing one, i realized, that there are no dac outputs. :/
    i'm having an almost builted sythesizer hardware for the 3.5/3.6 so i'm wondering if there is an alternative way to get a dac-like signal out of the 4.1?
    (and maybe, why would this feature not includet?)
    Greetings
    7,629
    Simple part, why there is not a DAC pin on the T4 or T4.1... The IMXRT1060 hardware does not have one.
    Alternatives - External DAC of some type. Or external I2S device.
    There is another output possible using the Medium Quality Sound (MQS - Chapter 38). Which there are two pins MQSL and MQSR you will see in yellow on the card for left and right channel.
    I don't do much audio so don't remember the state of using these with the Audio library or other libraries that make use of these.
    Hopefully someone else might know more.
    3,846
    KurtE is right, there is no direct DAC on the Teensy 4.0 or 4.1.
    As he mentions, there is the MQS system that provides a simple DAC like interface. However, the downside is it uses fixed pins 10 and 12 for the right and left channels. These pins are the primary CS pin and the MISO pin for the main SPI bus. So if you aren't using a SPI display, you could use them. With some SPI displays, you can use the second SPI bus (SPI1). On the Teensy 4.0, you would need to solder two wires to pads underneath the Teensy and use pins 0/1. On the Teensy 4.1, the two pads are now on pins 27 and 28. In addition you can switch the primary CS from pin 0 to pin 38, and the primary MISO1 to pin 39.
    There are other alternatives for sound output:
    I put together a list of some examples of the methods in the unofficial wiki:
    Sep 2020
    Massachusetts
    50
    ...What are the electrical connections needed for MQS?
    7,629
    Quote Originally Posted by blakeAlbion View Post
    There is data in the Wiki page that MichaelMeissner linked to.
    3,846
    When I did my test, I just used an adafruit amplifier and speaker. I don't remember exactly the setup. Perhaps it was one of the amplifiers and two speakers:
    More recently, I have been using the integrated speaker and amplifier, particularly for DACs:
    For the boards that have headphone output (3 band 3.5mm audio cable), I tend to use some of the headphone speakers I've collected:
    Sep 2020
    Massachusetts
    50
    Your tone sweep demo was extremely painful to listen to but super-helpful. This is just amazing.
