Results 1 to 2 of 2
Thread: Teensy 4.0 5V to 3.3V Encoder RS422 Differential Line Receiver?
    Feb 2021
    2
    I have a 5V encoder that I would like to connect to the 3.3V Teensy 4. I peeked in side the encoder housing and found that it has a chip number AM26LS31C(RS422 Differential Line Driver). I googled what chip should be used for the receiver and found number AM26LS32AC(RS422 Differential Line Receiver).
    I looked at the data sheet but unfortunately I don't know how to interpret the info on it very well Does anyone have experience with these part numbers on a 3.3V Teensy 4? If the line receiver above won't work does anyone know of the correct one for the Teensy voltage range?
    Also what would be the recommend way to connect a 5V encoder to the 3.3V Teensy when just using the A and B without the /A /B and not involving a RS422 differential signal? I googled and made a voltage divider but wants sure if there was something better or not.
    Here is the link to the data sheets:
    https://www.ti.com/lit/ds/symlink/am...oogle.com%252F
    Here is a picture of the encoder:
ID:	23879 Click image for larger version.
    Thank you,
    Jul 2020
    1,753
    A and #A form a pair, B and #B form a pair - those can be routed as twisted pairs, but twisting A with B will risk
    crosstalk between the quadrature channels.
    Each RS422 pair needs termination at the receiving end, a 120 ohm resistor is a reasonable match to CAT5 or similar cable.
    Its best to use a differential receiver (the AM26L32 available: https://uk.farnell.com/texas-instrum...97?st=am26ls32)
    For single ended output you can probably get away with a simple resistor divider as you think, using A/GND and B/GND
    as twisted pairs, again terminated with about 120 ohms and check the voltages you actually get with a meter are suitable
    for 3.3V logic - if not you'll need that receiver chip or at least a dual comparator - differential is the preferred approach.
