Hi currently I would like to use the teensy3.6 with the HX8357_t3 featherwing 3.5 inch, and started reading on the forum here.
so I tried:
the displays flashes in various light strengths, so I know it is communicating the teensy3.6. Originally I would like to use the teensy4.1 accordingly. but have the teensy3.6 on my breadboard at the moment.
I double checked the connections and placed the gnd and 3.3V pin to the other side:
https://learn.adafruit.com/adafruit-3-5-tft-featherwing/pinouts
https://forum.pjrc.com/threads/54982-TEENSY-3-6-ADAFRUIT-3-5-quot-TFT-touch-controller-issue
the 3.3V and gnd pins are on the other side?, this does not seem to work for me and doesnt allow the display to be powered.
what I get on my screen if I use the graphicstest from the ILI9341 example is:
from the HX8357 Example graphicstest Serialmonitor:
graphicstest ILI9341
best
Bastiaan
so I tried:
changing the DC, and CS as proposed by one of the chats here.
changing the ILI9341_T3 library and changed the size of the screen in the ILI9341_T3.h library.
changing the speed to max 16MHz and 24MHz by SPIsettings start and endtransaction at void setup and void loop
adding delays between the tft.begin() and tft_fillScreen 10, 100ms.
ILI9341 Test!
Display Power Mode: 0xFF
MADCTL Mode: 0xFF
Pixel Format: 0xFF
Image Format: 0xFF
Self Diagnostic: 0xFF
Benchmark Time (microseconds)
Screen fill 449773
Text 10691
Proportional Text 10384
Lines 116843
Horiz/Vert Lines 36337
Rectangles (outline) 20162
Rectangles (filled) 1088456
Circles (filled) 138226
Circles (outline) 95759
Triangles (outline) 25293
Triangles (filled) 351669
Rounded rects (outline) 33136
Rounded rects (filled) 1182429
Done!
_t3n::begin - completed
HX8357 Test!
MADCTL Mode: 0xFF
Pixel Format: 0xFF
Image Format: 0xFF
Screen fill 641001
Text 128352
Lines 165269
Horiz/Vert Lines 51872
Rectangles (outline) 28788
Rectangles (filled) 1549397
Circles (filled) 196521
Circles (outline) 135875
Triangles (outline) 35788
Triangles (filled) 500166
Rounded rects (outline) 64300
Rounded rects (filled) 1683341
Done!
This is our GFX example for the Adafruit HX8357 Breakout and Shield
----> http://www.adafruit.com/products/1651
Check out the links above for our tutorials and wiring diagrams
These displays use SPI to communicate, 4 or 5 pins are required to
interface (RST is optional)
products from Adafruit!
MIT license, all text above must be included in any redistribution
#include "SPI.h"
#include "HX8357_t3n.h"
// For the Adafruit shield, these are the default.
#define TFT_DC 10
#define TFT_CS 9
#define TFT_RST -1
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
HX8357_t3n tft = HX8357_t3n(TFT_CS, TFT_DC, TFT_RST);
tft.begin();
tft.fillScreen(HX8357_BLACK);
tft.setTextColor(HX8357_YELLOW);
tft.setTextSize(2);
tft.println("Waiting for Arduino Serial Monitor...");
Serial.println("HX8357 Test!");
// read diagnostics (optional but can help debug problems)
uint8_t x = tft.readcommand8(HX8357_RDMODE);
Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDMADCTL);
Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDPIXFMT);
Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDIMGFMT);
Serial.print("Image Format: 0x"); Serial.println(x, HEX);
x = tft.readcommand8(HX8357_RDSELFDIAG);
Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
Serial.println(F("Benchmark Time (microseconds)"));
Serial.print(F("Screen fill "));
Serial.println(testFillScreen());
delay(200);
Serial.print(F("Text "));
Serial.println(testText());
delay(600);
Serial.print(F("Lines "));
Serial.println(testLines(HX8357_CYAN));
delay(200);
Serial.print(F("Horiz/Vert Lines "));
Serial.println(testFastLines(HX8357_RED, HX8357_BLUE));
delay(200);
Serial.print(F("Rectangles (outline) "));
Serial.println(testRects(HX8357_GREEN));
delay(200);
Serial.print(F("Rectangles (filled) "));
Serial.println(testFilledRects(HX8357_YELLOW, HX8357_MAGENTA));
delay(200);
Serial.print(F("Circles (filled) "));
Serial.println(testFilledCircles(10, HX8357_MAGENTA));
Serial.print(F("Circles (outline) "));
Serial.println(testCircles(10, HX8357_WHITE));
delay(200);
Serial.print(F("Triangles (outline) "));
Serial.println(testTriangles());
delay(200);
Serial.print(F("Triangles (filled) "));
Serial.println(testFilledTriangles());
delay(200);
Serial.print(F("Rounded rects (outline) "));
Serial.println(testRoundRects());
delay(200);
Serial.print(F("Rounded rects (filled) "));
Serial.println(testFilledRoundRects());
delay(200);
Serial.println(F("Done!"));
void loop(void) {
for(uint8_t rotation=0; rotation<4; rotation++) {
tft.setRotation(rotation);
testText();
unsigned long testFillScreen() {
unsigned long start = micros();
tft.fillScreen(HX8357_RED);
tft.fillScreen(HX8357_GREEN);
tft.fillScreen(HX8357_BLUE);
return micros() - start;
unsigned long testText() {
tft.setCursor(0, 0);
tft.setTextColor(HX8357_WHITE); tft.setTextSize(1);
tft.println("Hello World!");
tft.setTextColor(HX8357_YELLOW); tft.setTextSize(2);
tft.println(1234.56);
tft.setTextColor(HX8357_RED); tft.setTextSize(3);
tft.println(0xDEADBEEF, HEX);
tft.println();
tft.setTextColor(HX8357_GREEN);
tft.setTextSize(5);
tft.println("Groop");
tft.setTextSize(2);
tft.println("I implore thee,");
tft.setTextSize(1);
tft.println("my foonting turlingdromes.");
tft.println("And hooptiously drangle me");
tft.println("with crinkly bindlewurdles,");
tft.println("Or I will rend thee");
tft.println("in the gobberwarts");
tft.println("with my blurglecruncheon,");
tft.println("see if I don't!");
tft.println(F("Alice was beginning to get very tired of sitting by her sister on the bank, and of having nothing to do: once or twice she had peeped into the book her sister was reading, but it had no pictures or conversations in it, 'and what is the use of a book,' thought Alice 'without pictures or conversations?'"));
tft.println(F("So she was considering in her own mind (as well as she could, for the hot day made her feel very sleepy and stupid), whether the pleasure of making a daisy-chain would be worth the trouble of getting up and picking the daisies, when suddenly a White Rabbit with pink eyes ran close by her."));
tft.println(F("There was nothing so very remarkable in that; nor did Alice think it so very much out of the way to hear the Rabbit say to itself, 'Oh dear! Oh dear! I shall be late!' (when she thought it over afterwards, it occurred to her that she ought to have wondered at this, but at the time it all seemed quite natural); but when the Rabbit actually took a watch out of its waistcoat-pocket, and looked at it, and then hurried on, Alice started to her feet, for it flashed across her mind that she had never before seen a rabbit with either a waistcoat-pocket, or a watch to take out of it, and burning with curiosity, she ran across the field after it, and fortunately was just in time to see it pop down a large rabbit-hole under the hedge."));
tft.println(F("In another moment down went Alice after it, never once considering how in the world she was to get out again."));
tft.println(F("The rabbit-hole went straight on like a tunnel for some way, and then dipped suddenly down, so suddenly that Alice had not a moment to think about stopping herself before she found herself falling down a very deep well."));
tft.println(F("Either the well was very deep, or she fell very slowly, for she had plenty of time as she went down to look about her and to wonder what was going to happen next. First, she tried to look down and make out what she was coming to, but it was too dark to see anything; then she looked at the sides of the well, and noticed that they were filled with cupboards and book-shelves; here and there she saw maps and pictures hung upon pegs. She took down a jar from one of the shelves as she passed; it was labelled 'ORANGE MARMALADE', but to her great disappointment it was empty: she did not like to drop the jar for fear of killing somebody, so managed to put it into one of the cupboards as she fell past it."));
unsigned long testLines(uint16_t color) {
unsigned long start, t;
int x1, y1, x2, y2,
w = tft.width(),
h = tft.height();
x1 = y1 = 0;
y2 = h - 1;
start = micros();
for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
x2 = w - 1;
for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
t = micros() - start; // fillScreen doesn't count against timing
x1 = w - 1;
y1 = 0;
y2 = h - 1;
start = micros();
x2 = 0;
t += micros() - start;
x1 = 0;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = w - 1;
x1 = w - 1;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = 0;
unsigned long testFastLines(uint16_t color1, uint16_t color2) {
unsigned long start;
int x, y, w = tft.width(), h = tft.height();
start = micros();
for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
unsigned long testRects(uint16_t color) {
int n, i, i2,
cx = tft.width() / 2,
cy = tft.height() / 2;
n = min(tft.width(), tft.height());
start = micros();
for(i=2; i<n; i+=6) {
i2 = i / 2;
tft.drawRect(cx-i2, cy-i2, i, i, color);
unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
unsigned long start, t = 0;
int n, i, i2,
cx = tft.width() / 2 - 1,
cy = tft.height() / 2 - 1;
n = min(tft.width(), tft.height()) - 1;
for(i=n; i>0; i-=6) {
i2 = i / 2;
start = micros();
tft.fillRect(cx-i2, cy-i2, i, i, color1);
// Outlines are not included in timing results
tft.drawRect(cx-i2, cy-i2, i, i, color2);
return t;
unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
start = micros();
for(x=radius; x<w; x+=r2) {
for(y=radius; y<h; y+=r2) {
tft.fillCircle(x, y, radius, color);
unsigned long testCircles(uint8_t radius, uint16_t color) {
int x, y, r2 = radius * 2,
w = tft.width() + radius,
h = tft.height() + radius;
// Screen is not cleared for this one -- this is
// intentional and does not affect the reported time.
start = micros();
for(x=0; x<w; x+=r2) {
for(y=0; y<h; y+=r2) {
tft.drawCircle(x, y, radius, color);
unsigned long testTriangles() {
int n, i, cx = tft.width() / 2 - 1,
n = min(cx, cy);
start = micros();
for(i=0; i<n; i+=5) {
tft.drawTriangle(
cx , cy - i, // peak
cx - i, cy + i, // bottom left
cx + i, cy + i, // bottom right
tft.color565(0, 0, i));
unsigned long testFilledTriangles() {
int i, cx = tft.width() / 2 - 1,
start = micros();
for(i=min(cx,cy); i>10; i-=5) {
start = micros();
tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(0, i, i));
tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
tft.color565(i, i, 0));
return t;
unsigned long testRoundRects() {
int w, i, i2,
w = min(tft.width(), tft.height()) - 1;
start = micros();
for(i=0; i<w; i+=6) {
i2 = i / 2;
tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
unsigned long testFilledRoundRects() {
int i, i2,
start = micros();
for(i=min(tft.width(), tft.height()) - 1; i>20; i-=6) {
i2 = i / 2;
tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i2, 0));
This is our GFX example for the Adafruit ILI9341 Breakout and Shield
#include "SPI.h"
#include "ILI9341_t3.h"
#include "font_Arial.h"
#define TFT_DC 10
#define TFT_CS 9
tft.begin();
// Note: you can now set the SPI speed to any value
// the default value is 30Mhz, but most ILI9341 displays
// can handle at least 60Mhz and as much as 100Mhz
//tft.setClock(60000000);
delay(10);
tft.setTextColor(ILI9341_YELLOW);
tft.setTextSize(2);
Serial.println("ILI9341 Test!");
uint8_t x = tft.readcommand8(ILI9341_RDMODE);
x = tft.readcommand8(ILI9341_RDMADCTL);
x = tft.readcommand8(ILI9341_RDPIXFMT);
x = tft.readcommand8(ILI9341_RDIMGFMT);
x = tft.readcommand8(ILI9341_RDSELFDIAG);
delay(200);
delay(600);
Serial.print(F("Proportional Text "));
Serial.println(testProportionalText());
delay(600);
Serial.println(testLines(ILI9341_CYAN));
delay(200);
Serial.println(testFastLines(ILI9341_RED, ILI9341_BLUE));
delay(200);
Serial.println(testRects(ILI9341_GREEN));
delay(200);
Serial.println(testFilledRects(ILI9341_YELLOW, ILI9341_MAGENTA));
delay(200);
Serial.println(testFilledCircles(10, ILI9341_MAGENTA));
Serial.println(testCircles(10, ILI9341_WHITE));
delay(200);
delay(200);
delay(200);
delay(200);
delay(200);
void loop(void) {
testText();
tft.fillScreen(ILI9341_RED);
tft.fillScreen(ILI9341_GREEN);
tft.fillScreen(ILI9341_BLUE);
tft.setTextColor(ILI9341_WHITE); tft.setTextSize(1);
tft.setTextColor(ILI9341_YELLOW); tft.setTextSize(2);
tft.setTextColor(ILI9341_RED); tft.setTextSize(3);
tft.println();
tft.setTextColor(ILI9341_GREEN);
tft.setTextSize(5);
tft.setTextSize(2);
tft.setTextSize(1);
unsigned long testProportionalText() {
tft.setTextColor(ILI9341_WHITE); tft.setFont(Arial_10);
tft.setTextColor(ILI9341_YELLOW); tft.setFont(Arial_16);
tft.setTextColor(ILI9341_RED); tft.setFont(Arial_24);
tft.println();
tft.setFont(Arial_40);
tft.setFontAdafruit();
int x1, y1, x2, y2,
w = tft.width(),
h = tft.height();
x1 = y1 = 0;
y2 = h - 1;
start = micros();
x2 = w - 1;
x1 = w - 1;
y1 = 0;
y2 = h - 1;
start = micros();
x2 = 0;
x1 = 0;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = w - 1;
x1 = w - 1;
y1 = h - 1;
y2 = 0;
start = micros();
x2 = 0;
start = micros();
int n, i, i2,
start = micros();
i2 = i / 2;
int n, i, i2,
i2 = i / 2;
start = micros();
return t;
start = micros();
start = micros();
n = min(cx, cy);
start = micros();
tft.drawTriangle(
start = micros();
start = micros();
return t;
int w, i, i2,
start = micros();
i2 = i / 2;
int i, i2,
start = micros();
i2 = i / 2;
tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
best
Bastiaan
