Results 1 to 8 of 8
Thread: problems HX8357
    Sep 2016
    105
    problems HX8357
    Hi currently I would like to use the teensy3.6 with the HX8357_t3 featherwing 3.5 inch, and started reading on the forum here.
    so I tried:
    • changing the DC, and CS as proposed by one of the chats here.
      changing the ILI9341_T3 library and changed the size of the screen in the ILI9341_T3.h library.
      changing the speed to max 16MHz and 24MHz by SPIsettings start and endtransaction at void setup and void loop
      adding delays between the tft.begin() and tft_fillScreen 10, 100ms.
    the displays flashes in various light strengths, so I know it is communicating the teensy3.6. Originally I would like to use the teensy4.1 accordingly. but have the teensy3.6 on my breadboard at the moment.
    I double checked the connections and placed the gnd and 3.3V pin to the other side:
    https://learn.adafruit.com/adafruit-...erwing/pinouts
    https://forum.pjrc.com/threads/54982...ntroller-issue
    the 3.3V and gnd pins are on the other side?, this does not seem to work for me and doesnt allow the display to be powered.
    what I get on my screen if I use the graphicstest from the ILI9341 example is:
    ILI9341 Test!
    Display Power Mode: 0xFF
    MADCTL Mode: 0xFF
    Pixel Format: 0xFF
    Image Format: 0xFF
    Self Diagnostic: 0xFF
    Benchmark                Time (microseconds)
    Screen fill              449773
    Text                     10691
    Proportional Text        10384
    Lines                    116843
    Horiz/Vert Lines         36337
    Rectangles (outline)     20162
    Rectangles (filled)      1088456
    Circles (filled)         138226
    Circles (outline)        95759
    Triangles (outline)      25293
    Triangles (filled)       351669
    Rounded rects (outline)  33136
    Rounded rects (filled)   1182429
    Done!
    from the HX8357 Example graphicstest Serialmonitor:
    _t3n::begin - completed
    HX8357 Test!
    MADCTL Mode: 0xFF
    Pixel Format: 0xFF
    Image Format: 0xFF
    Screen fill              641001
    Text                     128352
    Lines                    165269
    Horiz/Vert Lines         51872
    Rectangles (outline)     28788
    Rectangles (filled)      1549397
    Circles (filled)         196521
    Circles (outline)        135875
    Triangles (outline)      35788
    Triangles (filled)       500166
    Rounded rects (outline)  64300
    Rounded rects (filled)   1683341
    Done!
      This is our GFX example for the Adafruit HX8357 Breakout and Shield
      ----> http://www.adafruit.com/products/1651
      Check out the links above for our tutorials and wiring diagrams
      These displays use SPI to communicate, 4 or 5 pins are required to
      interface (RST is optional)
      products from Adafruit!
      MIT license, all text above must be included in any redistribution
    #include "SPI.h"
    #include "HX8357_t3n.h"
    // For the Adafruit shield, these are the default.
    #define TFT_DC  10
    #define TFT_CS 9
    #define TFT_RST -1
    // Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
    HX8357_t3n tft = HX8357_t3n(TFT_CS, TFT_DC, TFT_RST);
      tft.begin();
      tft.fillScreen(HX8357_BLACK);
      tft.setTextColor(HX8357_YELLOW);
      tft.setTextSize(2);
      tft.println("Waiting for Arduino Serial Monitor...");
      while (!Serial) ; // wait for Arduino Serial Monitor
      Serial.println("HX8357 Test!");
      // read diagnostics (optional but can help debug problems)
      uint8_t x = tft.readcommand8(HX8357_RDMODE);
      Serial.print("Display Power Mode: 0x"); Serial.println(x, HEX);
      x = tft.readcommand8(HX8357_RDMADCTL);
      Serial.print("MADCTL Mode: 0x"); Serial.println(x, HEX);
      x = tft.readcommand8(HX8357_RDPIXFMT);
      Serial.print("Pixel Format: 0x"); Serial.println(x, HEX);
      x = tft.readcommand8(HX8357_RDIMGFMT);
      Serial.print("Image Format: 0x"); Serial.println(x, HEX);
      x = tft.readcommand8(HX8357_RDSELFDIAG);
      Serial.print("Self Diagnostic: 0x"); Serial.println(x, HEX);
      Serial.println(F("Benchmark                Time (microseconds)"));
      Serial.print(F("Screen fill              "));
      Serial.println(testFillScreen());
      delay(200);
      Serial.print(F("Text                     "));
      Serial.println(testText());
      delay(600);
      Serial.print(F("Lines                    "));
      Serial.println(testLines(HX8357_CYAN));
      delay(200);
      Serial.print(F("Horiz/Vert Lines         "));
      Serial.println(testFastLines(HX8357_RED, HX8357_BLUE));
      delay(200);
      Serial.print(F("Rectangles (outline)     "));
      Serial.println(testRects(HX8357_GREEN));
      delay(200);
      Serial.print(F("Rectangles (filled)      "));
      Serial.println(testFilledRects(HX8357_YELLOW, HX8357_MAGENTA));
      delay(200);
      Serial.print(F("Circles (filled)         "));
      Serial.println(testFilledCircles(10, HX8357_MAGENTA));
      Serial.print(F("Circles (outline)        "));
      Serial.println(testCircles(10, HX8357_WHITE));
      delay(200);
      Serial.print(F("Triangles (outline)      "));
      Serial.println(testTriangles());
      delay(200);
      Serial.print(F("Triangles (filled)       "));
      Serial.println(testFilledTriangles());
      delay(200);
      Serial.print(F("Rounded rects (outline)  "));
      Serial.println(testRoundRects());
      delay(200);
      Serial.print(F("Rounded rects (filled)   "));
      Serial.println(testFilledRoundRects());
      delay(200);
      Serial.println(F("Done!"));
    void loop(void) {
      for(uint8_t rotation=0; rotation<4; rotation++) {
        tft.setRotation(rotation);
        testText();
    unsigned long testFillScreen() {
      unsigned long start = micros();
      tft.fillScreen(HX8357_RED);
      tft.fillScreen(HX8357_GREEN);
      tft.fillScreen(HX8357_BLUE);
      return micros() - start;
    unsigned long testText() {
      tft.setCursor(0, 0);
      tft.setTextColor(HX8357_WHITE);  tft.setTextSize(1);
      tft.println("Hello World!");
      tft.setTextColor(HX8357_YELLOW); tft.setTextSize(2);
      tft.println(1234.56);
      tft.setTextColor(HX8357_RED);    tft.setTextSize(3);
      tft.println(0xDEADBEEF, HEX);
      tft.println();
      tft.setTextColor(HX8357_GREEN);
      tft.setTextSize(5);
      tft.println("Groop");
      tft.setTextSize(2);
      tft.println("I implore thee,");
      tft.setTextSize(1);
      tft.println("my foonting turlingdromes.");
      tft.println("And hooptiously drangle me");
      tft.println("with crinkly bindlewurdles,");
      tft.println("Or I will rend thee");
      tft.println("in the gobberwarts");
      tft.println("with my blurglecruncheon,");
      tft.println("see if I don't!");
      tft.println(F("Alice was beginning to get very tired of sitting by her sister on the bank, and of having nothing to do: once or twice she had peeped into the book her sister was reading, but it had no pictures or conversations in it, 'and what is the use of a book,' thought Alice 'without pictures or conversations?'"));
      tft.println(F("So she was considering in her own mind (as well as she could, for the hot day made her feel very sleepy and stupid), whether the pleasure of making a daisy-chain would be worth the trouble of getting up and picking the daisies, when suddenly a White Rabbit with pink eyes ran close by her."));
      tft.println(F("There was nothing so very remarkable in that; nor did Alice think it so very much out of the way to hear the Rabbit say to itself, 'Oh dear! Oh dear! I shall be late!' (when she thought it over afterwards, it occurred to her that she ought to have wondered at this, but at the time it all seemed quite natural); but when the Rabbit actually took a watch out of its waistcoat-pocket, and looked at it, and then hurried on, Alice started to her feet, for it flashed across her mind that she had never before seen a rabbit with either a waistcoat-pocket, or a watch to take out of it, and burning with curiosity, she ran across the field after it, and fortunately was just in time to see it pop down a large rabbit-hole under the hedge."));
      tft.println(F("In another moment down went Alice after it, never once considering how in the world she was to get out again."));
      tft.println(F("The rabbit-hole went straight on like a tunnel for some way, and then dipped suddenly down, so suddenly that Alice had not a moment to think about stopping herself before she found herself falling down a very deep well."));
      tft.println(F("Either the well was very deep, or she fell very slowly, for she had plenty of time as she went down to look about her and to wonder what was going to happen next. First, she tried to look down and make out what she was coming to, but it was too dark to see anything; then she looked at the sides of the well, and noticed that they were filled with cupboards and book-shelves; here and there she saw maps and pictures hung upon pegs. She took down a jar from one of the shelves as she passed; it was labelled 'ORANGE MARMALADE', but to her great disappointment it was empty: she did not like to drop the jar for fear of killing somebody, so managed to put it into one of the cupboards as she fell past it."));
    unsigned long testLines(uint16_t color) {
      unsigned long start, t;
      int           x1, y1, x2, y2,
                    w = tft.width(),
                    h = tft.height();
      x1 = y1 = 0;
      y2    = h - 1;
      start = micros();
      for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
      x2    = w - 1;
      for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
      t     = micros() - start; // fillScreen doesn't count against timing
      x1    = w - 1;
      y1    = 0;
      y2    = h - 1;
      start = micros();
      x2    = 0;
      t    += micros() - start;
      x1    = 0;
      y1    = h - 1;
      y2    = 0;
      start = micros();
      x2    = w - 1;
      x1    = w - 1;
      y1    = h - 1;
      y2    = 0;
      start = micros();
      x2    = 0;
    unsigned long testFastLines(uint16_t color1, uint16_t color2) {
      unsigned long start;
      int           x, y, w = tft.width(), h = tft.height();
      start = micros();
      for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
      for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
    unsigned long testRects(uint16_t color) {
      int           n, i, i2,
                    cx = tft.width()  / 2,
                    cy = tft.height() / 2;
      n     = min(tft.width(), tft.height());
      start = micros();
      for(i=2; i<n; i+=6) {
        i2 = i / 2;
        tft.drawRect(cx-i2, cy-i2, i, i, color);
    unsigned long testFilledRects(uint16_t color1, uint16_t color2) {
      unsigned long start, t = 0;
      int           n, i, i2,
                    cx = tft.width()  / 2 - 1,
                    cy = tft.height() / 2 - 1;
      n = min(tft.width(), tft.height()) - 1;
      for(i=n; i>0; i-=6) {
        i2    = i / 2;
        start = micros();
        tft.fillRect(cx-i2, cy-i2, i, i, color1);
        // Outlines are not included in timing results
        tft.drawRect(cx-i2, cy-i2, i, i, color2);
      return t;
    unsigned long testFilledCircles(uint8_t radius, uint16_t color) {
      int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
      start = micros();
      for(x=radius; x<w; x+=r2) {
        for(y=radius; y<h; y+=r2) {
          tft.fillCircle(x, y, radius, color);
    unsigned long testCircles(uint8_t radius, uint16_t color) {
      int           x, y, r2 = radius * 2,
                    w = tft.width()  + radius,
                    h = tft.height() + radius;
      // Screen is not cleared for this one -- this is
      // intentional and does not affect the reported time.
      start = micros();
      for(x=0; x<w; x+=r2) {
        for(y=0; y<h; y+=r2) {
          tft.drawCircle(x, y, radius, color);
    unsigned long testTriangles() {
      int           n, i, cx = tft.width()  / 2 - 1,
      n     = min(cx, cy);
      start = micros();
      for(i=0; i<n; i+=5) {
        tft.drawTriangle(
          cx    , cy - i, // peak
          cx - i, cy + i, // bottom left
          cx + i, cy + i, // bottom right
          tft.color565(0, 0, i));
    unsigned long testFilledTriangles() {
      int           i, cx = tft.width()  / 2 - 1,
      start = micros();
      for(i=min(cx,cy); i>10; i-=5) {
        start = micros();
        tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
          tft.color565(0, i, i));
        tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
          tft.color565(i, i, 0));
      return t;
    unsigned long testRoundRects() {
      int           w, i, i2,
      w     = min(tft.width(), tft.height()) - 1;
      start = micros();
      for(i=0; i<w; i+=6) {
        i2 = i / 2;
        tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
    unsigned long testFilledRoundRects() {
      int           i, i2,
      start = micros();
      for(i=min(tft.width(), tft.height()) - 1; i>20; i-=6) {
        i2 = i / 2;
        tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i2, 0));
    graphicstest ILI9341
      This is our GFX example for the Adafruit ILI9341 Breakout and Shield
    #include "SPI.h"
    #include "ILI9341_t3.h"
    #include "font_Arial.h"
    #define TFT_DC  10
    #define TFT_CS 9
      tft.begin();
    // Note: you can now set the SPI speed to any value
    // the default value is 30Mhz, but most ILI9341 displays
    // can handle at least 60Mhz and as much as 100Mhz
      //tft.setClock(60000000);
      delay(10);
      tft.setTextColor(ILI9341_YELLOW);
      tft.setTextSize(2);
      Serial.println("ILI9341 Test!");
      uint8_t x = tft.readcommand8(ILI9341_RDMODE);
      x = tft.readcommand8(ILI9341_RDMADCTL);
      x = tft.readcommand8(ILI9341_RDPIXFMT);
      x = tft.readcommand8(ILI9341_RDIMGFMT);
      x = tft.readcommand8(ILI9341_RDSELFDIAG);
      delay(200);
      delay(600);
      Serial.print(F("Proportional Text        "));
      Serial.println(testProportionalText());
      delay(600);
      Serial.println(testLines(ILI9341_CYAN));
      delay(200);
      Serial.println(testFastLines(ILI9341_RED, ILI9341_BLUE));
      delay(200);
      Serial.println(testRects(ILI9341_GREEN));
      delay(200);
      Serial.println(testFilledRects(ILI9341_YELLOW, ILI9341_MAGENTA));
      delay(200);
      Serial.println(testFilledCircles(10, ILI9341_MAGENTA));
      Serial.println(testCircles(10, ILI9341_WHITE));
      delay(200);
      delay(200);
      delay(200);
      delay(200);
      delay(200);
    void loop(void) {
        testText();
      tft.fillScreen(ILI9341_RED);
      tft.fillScreen(ILI9341_GREEN);
      tft.fillScreen(ILI9341_BLUE);
      tft.setTextColor(ILI9341_WHITE);  tft.setTextSize(1);
      tft.setTextColor(ILI9341_YELLOW); tft.setTextSize(2);
      tft.setTextColor(ILI9341_RED);    tft.setTextSize(3);
      tft.println();
      tft.setTextColor(ILI9341_GREEN);
      tft.setTextSize(5);
      tft.setTextSize(2);
      tft.setTextSize(1);
    unsigned long testProportionalText() {
      tft.setTextColor(ILI9341_WHITE);  tft.setFont(Arial_10);
      tft.setTextColor(ILI9341_YELLOW); tft.setFont(Arial_16);
      tft.setTextColor(ILI9341_RED);    tft.setFont(Arial_24);
      tft.println();
      tft.setFont(Arial_40);
      tft.setFontAdafruit();
      int           x1, y1, x2, y2,
                    w = tft.width(),
                    h = tft.height();
      x1 = y1 = 0;
      y2    = h - 1;
      start = micros();
      x2    = w - 1;
      x1    = w - 1;
      y1    = 0;
      y2    = h - 1;
      start = micros();
      x2    = 0;
      x1    = 0;
      y1    = h - 1;
      y2    = 0;
      start = micros();
      x2    = w - 1;
      x1    = w - 1;
      y1    = h - 1;
      y2    = 0;
      start = micros();
      x2    = 0;
      start = micros();
      int           n, i, i2,
      start = micros();
        i2 = i / 2;
      int           n, i, i2,
        i2    = i / 2;
        start = micros();
      return t;
      start = micros();
      start = micros();
      n     = min(cx, cy);
      start = micros();
        tft.drawTriangle(
      start = micros();
        start = micros();
      return t;
      int           w, i, i2,
      start = micros();
        i2 = i / 2;
      int           i, i2,
      start = micros();
        i2 = i / 2;
        tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
    best
    Bastiaan
    Jul 2020
    318
    Have you soldered a blob on the SPI enable jumper pads on the HX8357D pcb? The silk screen says "Close IM2 for SPI" next to these pads.
    By default its configured for parallel, not SPI.
    There's also an Adafruit HX8357 library.
    Sep 2016
    105
    Hi Mark, thanks for the fast reply,
    The hx8357 with the featherwing 3.5 inch is being used.
    I tried also the HX8357 library from adafruit.
Name:	screen flashes.png
ID:	20970   Click image for larger version.
Name:	3_5inch tft featherwing backside connections.jpg
    Jul 2020
    318
    You've connected the power wrongly I think.
    pin 2 - 3.3V
    pin 4 - gnd
    pin 26 - Vusb = 5V
    pin 28 - Vbat = 3.7V
    You need 3.3V power to pins 2/4, and 5V to either pin 26 or 28. You've got the backlight driven via protection diodes
    at the moment I think.
    Sep 2016
    105
    thanks. that solved the problem. i needed also a 5V for the USB part. ok! many thanks! now I can combineit with the CN0391! thanks!
    Jul 2020
    318
    Quote Originally Posted by Bastiaan View Post
    I confess it took me way too long with the generic Adafruit HX8357 board to actually read their docs about the link I had to solder for SPI!
    7,416
    Yep - Been there
    Instructions on SPI is at: https://learn.adafruit.com/adafruit-...iring-and-test
    Quick FYI - I few of us worked on a faster version of the library that has most everything we put into some of the others like: ili9341_t3n, ILI9488_t3, ST7735_t3(ST7789_t3).
    I don't believe it is part of Teensyduino(yet) - But I think our most updated version is up at: https://github.com/mjs513/HX8357_t3n
    I use nearly the same display a HX8357 3.5" from Adafruit and currently I use the ILI9341_t3 lib--and it's works like a million bucks. As you found just need to change the display size in the .h file to 480 x 320.
    I will look at the HX8357_t3 lib--knowing KurtE and Co. it will sing.
