Results 1 to 4 of 4
Thread: prevent flickering by accessing ad7124 and hx8357 after each other
    Sep 2016
    106
    hello Tinkeres.
    by using the flicker free library the flashing of the display goes away. however how do I prevent flickering if two programs are run after each other in the void loop?
    ad7124 picks up data sends it away, closes the SPI bus,
    hx8357 opens the spi bus and posts the data on the screen.
    i crudely copied the codes to see if they work together, they do work,
    but the flicker, anyway to circumvent this?
    the speed is for ad7124 71ms.
    #include <ad7124.h>
    #include "Adafruit_GFX.h"
    #include "HX8357_t3n.h"
    #include <FlickerFreePrint.h>     // library to draw w/o flicker
    #define TFT_DC  9
    #define TFT_CS 10
    #define TFT_RST -1
    #define AD7124_CS 8
    #define AD7124_SPEED 5000000 // 2mhz?
    Ad7124Chip strainADC;
    #define TS_MINX 3800
    #define TS_MAXX 100
    #define TS_MINY 100
    #define TS_MAXY 3750
    #define C_BLACK      0x0000
    #define C_BLUE        0x001F
    #define C_RED         0xF800
    #define C_GREEN       0x07E0
    #define C_CYAN        0x07FF
    #define C_MAGENTA     0xF81F
    #define C_YELLOW      0xFFE0
    #define C_WHITE       0xFFFF
    HX8357_t3n tft = HX8357_t3n(TFT_CS, TFT_DC, TFT_RST);
    FlickerFreePrint<HX8357_t3n> Data1(&tft, C_WHITE, C_BLACK);
    FlickerFreePrint<HX8357_t3n> Data2(&tft, C_WHITE, C_BLACK);
    unsigned long endmicros;  //some global variables available anywhere in the program
    unsigned long currentmicros;
    const double Gain = 16;
    const double Rf = 5.11E3;
    const long Zero = 1L << 23;
    const long FullScale = 1L << 24;
    long SBraw[7];
    double SBvolt[7];
    long dataWord;
    byte statusWord;
    byte ch;
    /* constants ================================================================ */
    int filterWord = 100;
    // Sample Speed Setting (Full Power Sinc3 Filter Mode)
    //  FW  |  SPS  |  SPS/Ch
    //  600 |    6  |     1
    //  100 |   60  |    10
    //   40 |  156  |    26
    //   20 |  300  |    50
    float j;
    unsigned long StartTime, EndTime;
    char str[30];
    SPISettings settingsAD7124(5000000, MSBFIRST, SPI_MODE3);
    SPISettings settingsTFT(25000000, LSBFIRST, SPI_MODE3);
    #define TS_MAXX 100
    #define TS_MINY 100
    /* public variables ========================================================= */
    Ad7124Chip adc;
    /* internal public functions ================================================ */
        pinMode(AD7124_CS, OUTPUT);
      pinMode(TFT_CS, OUTPUT);
      SPI.begin();
         //Initialize serial and wait for port to open:
      Serial.begin (38400);
      while (!Serial) {
        ; // wait for serial port to connect. Needed for native USB port only
      // prints title with ending line break
      Serial.println ("AD7124 Voltmeter");
      digitalWrite(AD7124_CS,LOW);
      SPI.beginTransaction(settingsAD7124);
      // Initializes the AD7124 device, the pin /CS is pin 10 (/SS)
     // Loop until ADC responds
      int state = strainADC.begin(AD7124_CS);
      while (state < 0) {
        Serial.println(state);
        Serial.println ("Failed");
        delay(10);
      // Configuring ADC in Full Power Mode & Continuous Mode (Prevents sleep mode)
      strainADC.setAdcControl(Ad7124::ContinuousMode, Ad7124::FullPower, true);
      strainADC.setMode(Ad7124::ContinuousMode);
      // Configure Channel 0
      strainADC.setConfig(0, Ad7124::RefInternal, Ad7124::Pga1, true);
      strainADC.setConfigFilter(0, Ad7124::Sinc3Filter, filterWord);
      strainADC.setChannel(0, 0, Ad7124::AIN3Input, Ad7124::AIN2Input, true);
      // Configure Channel 1
      strainADC.setConfig(1, Ad7124::RefInternal, Ad7124::Pga1, true);
      strainADC.setConfigFilter(1, Ad7124::Sinc3Filter, filterWord);
      strainADC.setChannel(1, 1, Ad7124::AIN5Input, Ad7124::AIN4Input, true);
      // Configure Channel 2
      strainADC.setConfig(2, Ad7124::RefInternal, Ad7124::Pga1, true);
      strainADC.setConfigFilter(2, Ad7124::Sinc3Filter, filterWord);
      strainADC.setChannel(2, 2, Ad7124::AIN7Input, Ad7124::AIN6Input, true);
      // Configure Channel 3
      strainADC.setConfig(3, Ad7124::RefInternal, Ad7124::Pga1, true);
      strainADC.setConfigFilter(3, Ad7124::Sinc3Filter, filterWord);
      strainADC.setChannel(3, 3, Ad7124::AIN9Input, Ad7124::AIN8Input, true);
      // Configure Channel 4
      strainADC.setConfig(4, Ad7124::RefInternal, Ad7124::Pga1, true);
      strainADC.setConfigFilter(4, Ad7124::Sinc3Filter, filterWord);
      strainADC.setChannel(4, 4, Ad7124::AIN11Input, Ad7124::AIN10Input, true);
      // Configure Channel 5
      strainADC.setConfig(5, Ad7124::RefInternal, Ad7124::Pga1, true);
      strainADC.setConfigFilter(5, Ad7124::Sinc3Filter, filterWord);
      strainADC.setChannel(5, 5, Ad7124::AIN13Input, Ad7124::AIN12Input, true);
      strainADC.enableChannel(0,true);
      strainADC.enableChannel(1,true);
      strainADC.enableChannel(2,true);
      strainADC.enableChannel(3,true);
      strainADC.enableChannel(4,true);
      strainADC.enableChannel(5,true);
      strainADC.enableChannel(6,false);
      strainADC.enableChannel(7,false);
        digitalWrite (AD7124_CS, HIGH);// setting the CS Pin high
        SPI.endTransaction();
        SPI.beginTransaction(settingsTFT);
      digitalWrite(TFT_CS,LOW);
      tft.begin();
      tft.begin();
      tft.setRotation(1);
      tft.fillScreen(C_BLACK);
      tft.fillRect(0, 0, 319, 35, C_RED);
      tft.fillRect(0, 130, 319, 35, C_BLUE);
        // get some data
       currentmicros = micros();
       for (int i = 1; i <= 6; i++)
        strainADC.waitEndOfConversion(100);
        dataWord = strainADC.getData();
        ch = strainADC.currentChannel();
        // check RDY bit
        if (ch >= 0) {
          SBraw[ch + 1] = dataWord;
          SBvolt[ch] = Ad7124Chip::toVoltage(SBraw[ch], 1, 2.5, true);
      Serial.print("$");
      for (int i = 1; i <= 6; i++) {
        Serial.print(",");
        Serial.print(SBvolt[i]);
      Serial.print(" || ");
      Serial.print(currentmicros);
      Serial.print(micros());
        unsigned long endmicros=currentmicros-micros();
          Serial.print(endmicros);
        Serial.print(" usec");
        Serial.println("");
      tft.fillScreen(HX8357_BLACK);
      tft.setTextColor(HX8357_WHITE);  tft.setTextSize(1);
      tft.setCursor(0, 0);
      tft.println("Hello World!");
    ///----- flicker test
      j += 0.0013;
      // now let's see the tft update with FlickerFree
      tft.setCursor(10, 140);
      tft.setTextColor(C_WHITE, C_BLUE);
      tft.print("FlickerFree: ");
      // set cursor as you would normall do
      tft.setCursor(180, 140);
      // you must call the text colors for the object
      Data1.setTextColor(C_WHITE, C_BLUE);
      StartTime = millis();
      // one call and flicker free paint is done
      Data1.print(j, 4);
      // lets see how fast
      EndTime = millis() - StartTime;
      tft.setTextColor(C_WHITE, C_BLACK);
      tft.setCursor(10, 170);
      sprintf(str, "Update time: %lu", EndTime);
      Data2.setTextColor(C_WHITE, C_BLACK);
      Data2.print(str);
      digitalWrite(TFT_CS,HIGH);
    Serial monitor code:
    AD7124 Voltmeter
    _t3n::begin mosi:11 miso:12 SCLK:13 CS:10 DC:9 SPI clocks: 26000000 2000000
    _t3n::begin - completed
    $,-2.50,-0.00,-0.00,0.85,1.39,0.00 || 2402671 || 2478261 || 4294891703 usec
    thanks for reading.
Name:	flicker_with 2 programs.jpg
    Sep 2016
    106
    Solved!
    place the Data1.setTextColor to the beginning.
    7,420
    With most of our graphic libraries today, In cases like this, I typically solved flicker one of two ways:
    a) Use Frame buffer: But only T4.x has enough memory for the HX8357, for 16 bit colors... I have to look to see if we put in 8 bit version with color table for T3.5/6. But with these you can simply say use a frame buffer, and after you write everything to update the screen, call the method updateScreen which puts all of the bits on the screen in one shot avoiding flicker.
    b) Use Opaque text output. Suppose you have a text field, that uses pixels (100,100) (300, 125), The Psuedo code assuming left justify output, might be something like:
    Again assume white text on black background:
    tft.setTextColor(WHITE, BLACK);  // use the actual color constants from library
    tft.setTextCursor(100, 100);
    tft.print("New Text");
    int16_t x_text_cursor = tft.getCursorX();
    tft.fillRect(x_text_cursor, 100, 300-x_text_cursor, 25, BLACK); // fill to the end of field with background color.
    There are other optimizations one can do with the last fill. For example you can remember the last x_text_cursor, and only if the new one is less
    than the current one, do you do a fill rect and only need to do between those two points.
    Sep 2016
    106
    So technically you say to refresh a small area like an update on pwm signal/ temperature? And leave the rest out of the picture.
    Ok keep it in mind, it is reading the ad7124 with the hx8357 so fast <50ms I am very happy. Iíll reduce it to 10x a second which is more than enough.
    The ad7124 isnít working, probably Iíll have to change some register values but itís still pending at the analog devices.
