Processing teensy40 (platform: teensy; board: teensy40; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy40.html
PLATFORM: Teensy 4.10.0 > Teensy 4.0
HARDWARE: IMXRT1062 600MHz, 512KB RAM, 1.94MB Flash
DEBUG: Current (jlink) External (jlink)
PACKAGES:
- framework-arduinoteensy 1.153.0 (1.53)
- toolchain-gccarmnoneeabi 1.50401.190816 (5.4.1)
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 120 compatible libraries
Scanning dependencies...
Dependency Graph
|-- <Audio> 1.3
| |-- <SerialFlash> 0.0.0-alpha+sha.2b86eb1e43
| | |-- <SPI> 1.0
| |-- <SPI> 1.0
| |-- <Wire> 1.0
| |-- <SD> 1.2.2
| | |-- <SPI> 1.0
|-- <SD> 1.2.2
| |-- <SPI> 1.0
| |-- <SPI> 1.0
|-- <SPI> 1.0
|-- <Wire> 1.0
Building in release mode
Compiling .pio\build\teensy40\src\main.cpp.o
Compiling .pio\build\teensy40\libc3f\SPI\SPI.cpp.o
Compiling .pio\build\teensy40\libd0f\SerialFlash\SerialFlashChip.cpp.o
Compiling .pio\build\teensy40\libd0f\SerialFlash\SerialFlashDirectory.cpp.o
Compiling .pio\build\teensy40\libd90\Wire\Wire.cpp.o
Compiling .pio\build\teensy40\libd90\Wire\WireIMXRT.cpp.o
Compiling .pio\build\teensy40\libd90\Wire\WireKinetis.cpp.o
Compiling .pio\build\teensy40\libd90\Wire\utility\twi.c.o
Compiling .pio\build\teensy40\lib69b\SD\File.cpp.o
Compiling .pio\build\teensy40\lib69b\SD\SD.cpp.o
Compiling .pio\build\teensy40\lib69b\SD\cache_t3.cpp.o
Compiling .pio\build\teensy40\lib69b\SD\card_t3.cpp.o
Compiling .pio\build\teensy40\lib69b\SD\dir_t3.cpp.o
Compiling .pio\build\teensy40\lib69b\SD\fat_t3.cpp.o
Compiling .pio\build\teensy40\lib69b\SD\file_t3.cpp.o
In file included from .pio\libdeps\teensy40\Audio/effect_envelope.h:31:0,
from .pio\libdeps\teensy40\Audio/Audio.h:78,
from src\main.cpp:17:
.pio\libdeps\teensy40\Audio/utility/dspinst.h: In function 'int32_t signed_saturate_rshift(int32_t, int, int)':
.pio\libdeps\teensy40\Audio/utility/dspinst.h:51:1: warning: no return statement in function returning non-void [-Wreturn-type]
.pio\libdeps\teensy40\Audio/utility/dspinst.h: In function 'int16_t saturate16(int32_t)':
.pio\libdeps\teensy40\Audio/utility/dspinst.h:66:1: warning: no return statement in function returning non-void [-Wreturn-type]
.pio\libdeps\teensy40\Audio/utility/dspinst.h: In function 'int32_t signed_multiply_32x16b(int32_t, uint32_t)':
.pio\libdeps\teensy40\Audio/utility/dspinst.h:79:1: warning: no return statement in function returning non-void [-Wreturn-type]
.pio\libdeps\teensy40\Audio/utility/dspinst.h: In function 'int32_t signed_multiply_32x16t(int32_t, uint32_t)':
.pio\libdeps\teensy40\Audio/utility/dspinst.h:92:1: warning: no return statement in function returning non-void [-Wreturn-type]
.pio\libdeps\teensy40\Audio/utility/dspinst.h: In function 'int32_t multiply_32x32_rshift32(int32_t, int32_t)':
.pio\libdeps\teensy40\Audio/utility/dspinst.h:105:1: warning: no return statement in function returning non-void [-Wreturn-type]
.pio\libdeps\teensy40\Audio/utility/dspinst.h: In function 'int32_t multiply_32x32_rshift32_rounded(int32_t, int32_t)':
.pio\libdeps\teensy40\Audio/utility/dspinst.h:118:1: warning: no return statement in function returning non-void [-Wreturn-type]
Compiling .pio\build\teensy40\lib69b\SD\init_t3.cpp.o
Compiling .pio\build\teensy40\lib69b\SD\utility\NXP_SDHC.cpp.o
Compiling .pio\build\teensy40\lib69b\SD\utility\Sd2Card.cpp.o
.pio\libdeps\teensy40\Audio/utility/dspinst.h: In function 'int32_t multiply_accumulate_32x32_rshift32_rounded(int32_t, int32_t, int32_t)':
.pio\libdeps\teensy40\Audio/utility/dspinst.h:131:1: warning: no return statement in function returning non-void [-Wreturn-type]
.pio\libdeps\teensy40\Audio/utility/dspinst.h: In function 'int32_t multiply_subtract_32x32_rshift32_rounded(int32_t, int32_t, int32_t)':
.pio\libdeps\teensy40\Audio/utility/dspinst.h:144:1: warning: no return statement in function returning non-void [-Wreturn-type]
Compiling .pio\build\teensy40\lib69b\SD\utility\SdFile.cpp.o
.pio\libdeps\teensy40\Audio/utility/dspinst.h: In function 'uint32_t pack_16t_16t(int32_t, int32_t)':
.pio\libdeps\teensy40\Audio/utility/dspinst.h:158:1: warning: no return statement in function returning non-void [-Wreturn-type]
.pio\libdeps\teensy40\Audio/utility/dspinst.h: In function 'uint32_t pack_16t_16b(int32_t, int32_t)':
.pio\libdeps\teensy40\Audio/utility/dspinst.h:171:1: warning: no return statement in function returning non-void [-Wreturn-type]
.pio\libdeps\teensy40\Audio/utility/dspinst.h: In function 'uint32_t pack_16b_16b(int32_t, int32_t)':
.pio\libdeps\teensy40\Audio/utility/dspinst.h:184:1: warning: no return statement in function returning non-void [-Wreturn-type]
src\main.cpp: At global scope:
src\main.cpp:29:26: error: use of deleted function 'AudioMixer4::AudioMixer4()'
AudioMixer4 mixer1; //xy=486,163
In file included from .pio\libdeps\teensy40\Audio/Audio.h:97:0,
.pio\libdeps\teensy40\Audio/mixer.h:33:7: note: 'AudioMixer4::AudioMixer4()' is implicitly deleted because the default definition would be ill-formed:
class AudioMixer4 : public AudioStream
.pio\libdeps\teensy40\Audio/mixer.h:33:7: error: no matching function for call to 'AudioStream::AudioStream()'
In file included from .pio\libdeps\teensy40\Audio/analyze_fft256.h:31:0,
from .pio\libdeps\teensy40\Audio/Audio.h:61,
C:\users\jens\.platformio\packages\framework-arduinoteensy\cores\teensy4/AudioStream.h:123:2: note: candidate: AudioStream::AudioStream(unsigned char, audio_block_t**)
AudioStream(unsigned char ninput, audio_block_t **iqueue) :
C:\users\jens\.platformio\packages\framework-arduinoteensy\cores\teensy4/AudioStream.h:123:2: note: candidate expects 2 arguments, 0 provided
C:\users\jens\.platformio\packages\framework-arduinoteensy\cores\teensy4/AudioStream.h:120:7: note: candidate: constexpr AudioStream::AudioStream(const AudioStream&)
class AudioStream
C:\users\jens\.platformio\packages\framework-arduinoteensy\cores\teensy4/AudioStream.h:120:7: note: candidate expects 1 argument, 0 provided
C:\users\jens\.platformio\packages\framework-arduinoteensy\cores\teensy4/AudioStream.h:120:7: note: candidate: constexpr AudioStream::AudioStream(AudioStream&&)
src\main.cpp:29:26: error: cannot declare variable 'mixer1' to be of abstract type 'AudioMixer4'
.pio\libdeps\teensy40\Audio/mixer.h:33:7: note: because the following virtual functions are pure within 'AudioMixer4':
C:\users\jens\.platformio\packages\framework-arduinoteensy\cores\teensy4/AudioStream.h:173:15: note: virtual void AudioStream::update()
virtual void update(void) = 0;
src\main.cpp: In function 'void setup()':
src\main.cpp:69:10: error: 'class AudioMixer4' has no member named 'gain'
mixer1.gain(0, 0.5);
src\main.cpp:70:10: error: 'class AudioMixer4' has no member named 'gain'
mixer1.gain(1, 0.5);
*** [.pio\build\teensy40\src\main.cpp.o] Error 1
============================================================================================================================= [FAILED] Took 3.08 seconds =============================================================================================================================
The terminal process "C:\Users\jens\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
