I have run into a wierd problem wrt to Serial communication from Teensy 3.5 to PC.
Basically I am trying to send ADC values from Teensy to a PC for which I have modified the example sketch in the arduino. On the PC side I am using pyserial to receive the data.
The modifed arduino sketch is below:
I have only added some code to blink the onboard led on each execution of the loop.
When I connect the teensy to Windows 10(comes up as COM5 port) machine I can see the data using both, the arduino serial monitor and the pyserial library.
However when I connect it to a system running Debian 4.19. I do not seen anything on the serial port. The device is visible as /dev/ttyACM0, however when I do cat /dev/ttyACM0, nothing shows up in the terminal.
On python side I am using.
to start a serial session.
If I read data using ser.read(3), since I am sending 1 byte values and 2 bytes to CR/LF(arduino's println), it ugoes into infinite wait until I realised that pyserial has a blocking read function and if timeout is not given it will block till its gets the mentioned number of bytes.
Upon checking the input buffer using ser.in_waiting, I found that my input buffer is empty i.e 0.
From here on I am stuck and I don't know how to proceed, I searched on the forum but no one has had similar problem. I want to confirm again that everything works on Windows 10 PC but I want to leave the debian system to do some data collection at the sensor location.
Please accept my gratitude in advance !
Analog input, analog output, serial output
Reads an analog input pin, maps the result to a range from 0 to 255 and uses
the result to set the pulse width modulation (PWM) of an output pin.
Also prints the results to the Serial Monitor.
The circuit:
- potentiometer connected to analog pin 0.
Center pin of the potentiometer goes to the analog pin.
side pins of the potentiometer go to +5V and ground
- LED connected from digital pin 9 to ground
created 29 Dec. 2008
modified 9 Apr 2012
by Tom Igoe
http://www.arduino.cc/en/Tutorial/AnalogInOutSerial
// These constants won't change. They're used to give names to the pins used:
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
const int ledPin = LED_BUILTIN;
int sensorValue = 0; // value read from the pot
uint8_t outputValue = 0; // value output to the PWM (analog out)
bool ledState = 0;
// initialize serial communications at 9600 bps:
pinMode(ledPin, OUTPUT);
// read the analog in value:
sensorValue = analogRead(analogInPin);
// map it to the range of the analog out:
outputValue = map(sensorValue, 0, 1023, 0, 255);
// change the analog out value:
analogWrite(analogOutPin, outputValue);
// print the results to the Serial Monitor:
Serial.print("sensor = ");
Serial.print(sensorValue);
Serial.print("\t output = ");
Serial.println(outputValue);
ledState=!ledState;
digitalWrite(ledPin, ledState);
// wait 2 milliseconds before the next loop for the analog-to-digital
// converter to settle after the last reading:
ser = serial.Serial(
port ='/dev/ttyACM0',
baudrate = 9600,
bytesize = serial.EIGHTBITS
