Function generator 1Vpp 10kHz sawtooth -> Shield line input -> Teensy -> Shield Line output -> 100MHz scope.
Shield plugged into Teensy by simple socket, so all connections less than 10mm. Nothing else connected apart from USB to PC.
Running Example sketch PassThroughStereo.
Using the scope to look at the input to the shield is a perfect crisp sawtooth. Looking at the output is very low pass filtered.
Hopefully a photo is attached...
Surely I should be getting the same crisp sawtooth at the output too?
