I'm using VS Code/PlatformIO on MacOS 10.15.5 to develop code for a Teensy 4.0. I'd like to be able to generate a hex-format object file and send it to a collaborator so that he can download it to a T4 without having to replicate my development environment. It appears that a "firmware.hex" file is being generated during my normal build process, so I'm hoping that this file can be emailed to my friend and downloaded using only the Teensy Loader (which I assume he can install separately).
The build message is "Building .pio/build/teensy40/firmware.hex". I've been poking around but haven't been able to find this file, and I'm admittedly not an expert at finding hidden files. Are my assumptions/guesses above correct? If so, where can I find the hex file, or how can I generate it? Other forum searches haven't produced any clear results.
Thanks!
Thanks!
