Results 1 to 3 of 3
Thread: How to combine a mono and a stereo line inputs
    Mar 2019
    Hoboken, New Jersey, USA
    126
    How to combine mono and stereo line inputs
    I'm making a guitar effect "pedal" based on Teensy 4.1 and the Audio Board.
    It also has a Line Input, for "play along".
    The problem is that the guitar has only one channel, but I have to split one channel into 2 separate preamps only not to cross-connect the stereo Line In.
    Is there a better way? How do I add one guitar channel to the 2 Line In channels without mixing the 2 channels together.
    Hope I'm explaining it right. I want to have a stereo Line In and add one guitar preamp to it.
    Jul 2020
    350
    Assuming whatever's driving the line inputs is low impedance output, there won't be a problem passively mixing in the signal to
    each channel. Something like a few k ohms resistors would be suitable.
    Most audio equipment these days is has output impedances around a 100 ohms or so, and input impedance of 10k to 50k.
    Mar 2019
    126
    Silly me, totally forgot about it.
    Looked it up and see the resistors suggested ranging from 1K to 220K.
    What resistors would be good for the Teensy Audio Board?
    I guess 220K will loose more signal and 1K will add too much crossover, no?
