Results 1 to 5 of 5
Thread: Teensy 3.6 won't communicate with Raspberri Pi Serial
    Jul 2020
    2
    Hi All,
    I have a Teensy 4.0 and Teensy 3.6 to connect to a Raspberry Pi 3B+ (Running a fresh copy of Raspberry Pi OS) and use the python serial library to read the data.
    I use the same sketch and code for the Teensy 3.6 and Teensy 4.0, the Teensy 4.0 works fine and reliably to read the serial data on the Raspberry Pi but the Teensy 3.6 won't print anything to the Raspberry Pi.
    I have connected to a windows computer and the Teensy 3.6 and Teensy 4.0 both print correctly using the Teensy port and standard com port on the windows computer through the Arduino IDE.
    I installed the Arduino IDE onto the Raspberry Pi and I get the serial messages for the Teensy 4.0 but not for the Teensy 3.6, making me think there is some kind of serial problem with the Teensy 3.6 to the Raspberry Pi.
    I also tried a Arduino Uno and it works fine on the Raspberry Pi as well. The only issue I have is with the Teensy 3.6.
    I did have the Teensy setup for "Dual Serial" and changed it back to "Serial". Could this have caused the issues with the Teensy communicating with the Raspberry Pi?
    I need to use the Teensy 3.6 for the enhanced i2c_t3 library.
    Teensy Code:
      Serial.println("Hello from Teensy!");
      Serial.println(1);
      Serial.println(2);
      Serial.println(3);
      Serial.println(4);
    Python Code (Change between ttyACM0 and ttyACM1 to match result from dmesg | grep tty)
    import time
    import serial
    from serial.tools import list_ports
    print("Script Started")
    ser= serial.Serial('/dev/ttyACM0', 115200, timeout=1)
    data=0
    while True:
        if ser.in_waiting >0:
            data=ser.readline().decode('utf-8').rstrip()
            print(data)
    7,473
    I have not used a T3.6 with RPI in awhile, but it always used to work for me. Although I typically never used Python.
    It might help to see more debug data here.
    Usually when I had issues, I would look at the data like you mentioned for dmesg
    Often I will print out stuff like: Here is a quick run on RPI4 with T3.6
    pi@RPI4LSS:~ $ lsusb
    Bus 002 Device 002: ID 174c:55aa ASMedia Technology Inc. Name: ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
    Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 001 Device 004: ID 04ca:0027 Lite-On Technology Corp.
    Bus 001 Device 003: ID 046d:c063 Logitech, Inc. DELL Laser Mouse
    Bus 001 Device 005: ID 16c0:0483 Van Ooijen Technische Informatica Teensyduino Serial
    Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    pi@RPI4LSS:~ $ lsusb -v -d 16c0:0483
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceClass            2 Communications
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      idVendor           0x16c0 Van Ooijen Technische Informatica
      idProduct          0x0483 Teensyduino Serial
      bcdDevice            2.77
      iManufacturer           1 Teensyduino
      iProduct                2 USB Serial
      iSerial                 3 2416110
      bNumConfigurations      1
      Configuration Descriptor:
        bLength                 9
        bDescriptorType         2
        wTotalLength       0x0043
        bNumInterfaces          2
        bConfigurationValue     1
        iConfiguration          0
        bmAttributes         0xc0
          Self Powered
        MaxPower              100mA
        Interface Descriptor:
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          bInterfaceClass         2 Communications
          bInterfaceSubClass      2 Abstract (modem)
          bInterfaceProtocol      1 AT-commands (v.25ter)
          iInterface              0
          CDC Header:
            bcdCDC               1.10
          CDC Call Management:
            bmCapabilities       0x01
              call management
            bDataInterface          1
          CDC ACM:
            bmCapabilities       0x06
              sends break
              line coding and serial state
          CDC Union:
            bMasterInterface        0
            bSlaveInterface         1
          Endpoint Descriptor:
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x82  EP 2 IN
            bmAttributes            3
              Transfer Type            Interrupt
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0010  1x 16 bytes
            bInterval              64
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
          bInterfaceClass        10 CDC Data
          bInterfaceSubClass      0
          bInterfaceProtocol      0
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x03  EP 3 OUT
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            wMaxPacketSize     0x0040  1x 64 bytes
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bEndpointAddress     0x84  EP 4 IN
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
    can't get debug descriptor: Resource temporarily unavailable
    Device Status:     0x0000
      (Bus Powered)
    pi@RPI4LSS:~ $ ls /dev/ttyA*
    /dev/ttyACM0  /dev/ttyAMA0
    pi@RPI4LSS:~ $ dmesg | tail -40
    [    9.285651] bcmgenet fd580000.ethernet: configuring instance for external RGMII
    [    9.285935] bcmgenet fd580000.ethernet eth0: Link is Down
    [   10.219581] broken atomic modeset userspace detected, disabling atomic
    [   10.832857] broken atomic modeset userspace detected, disabling atomic
    [   11.855951] broken atomic modeset userspace detected, disabling atomic
    [   12.444283] broken atomic modeset userspace detected, disabling atomic
    [   13.468780] broken atomic modeset userspace detected, disabling atomic
    [   14.052423] broken atomic modeset userspace detected, disabling atomic
    [   14.716378] Bluetooth: Core ver 2.22
    [   14.716417] NET: Registered protocol family 31
    [   14.716422] Bluetooth: HCI device and connection manager initialized
    [   14.716434] Bluetooth: HCI socket layer initialized
    [   14.716442] Bluetooth: L2CAP socket layer initialized
    [   14.716455] Bluetooth: SCO socket layer initialized
    [   14.719966] Bluetooth: HCI UART driver ver 2.3
    [   14.719975] Bluetooth: HCI UART protocol H4 registered
    [   14.720011] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   14.720164] Bluetooth: HCI UART protocol Broadcom registered
    [   14.835687] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   14.835701] Bluetooth: BNEP filters: protocol multicast
    [   14.835738] Bluetooth: BNEP socket layer initialized
    [   14.875335] Bluetooth: RFCOMM TTY layer initialized
    [   14.875350] Bluetooth: RFCOMM socket layer initialized
    [   14.875364] Bluetooth: RFCOMM ver 1.11
    [   14.983238] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [   15.119348] broken atomic modeset userspace detected, disabling atomic
    [   15.675851] broken atomic modeset userspace detected, disabling atomic
    [   16.709949] broken atomic modeset userspace detected, disabling atomic
    [   17.297729] broken atomic modeset userspace detected, disabling atomic
    [   31.831566] vcc-sd: disabling
    [   71.168900] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
    [  456.458382] usb 1-1.2: new full-speed USB device number 5 using xhci_hcd
    [  456.593831] usb 1-1.2: New USB device found, idVendor=16c0, idProduct=0483, bcdDevice= 2.77
    [  456.593849] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [  456.593865] usb 1-1.2: Product: USB Serial
    [  456.593879] usb 1-1.2: Manufacturer: Teensyduino
    [  456.593893] usb 1-1.2: SerialNumber: 2416110
    [  456.635197] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
    [  456.637543] usbcore: registered new interface driver cdc_acm
    [  456.637556] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    pi@RPI4LSS:~ $
    Note If I do:
    pi@RPI4LSS:~ $ cat /dev/ttyACM0
    ILI9488 Test!
    You see that it output one line of text ... I know not overly conclusive, but without seeing additional information, not sure what else to tell you.
    Since you said T4 worked I assume you installed the udev rules as mentioned in the installation instructions for Teensyduino.
    12,231
    Didn't hit post before walking away - KurtE's attention may lead to solution - was going to note:
    Try adding this to setup before printing: while (!Serial && millis() < 4000 );
    Assuming the T_3.6 properly compiles with USB Type Serial selected - then finding the right port ... That will prevent the USB - for 4 seconds - from getting a barrage of prints before the rPi connects.
    Jul 2020
    2
    I did not have the udev rules installed.
    I installed them and nothing changed. It 's interesting that if I reboot the RPI and connect, the first time the script runs with the Teensy 3.6, the loop prints out once but then won't print anymore (as if it was stored in a buffer).
    I added in the "while (!Serial && millis() < 4000 );" into the Arduino setup and get the same results.
    Here are the lsusb command results:
    pi@raspberrypi:~ $ lsusb
    Bus 001 Device 009: ID 16c0:0483 Van Ooijen Technische Informatica Teensyduino Serial
    Bus 001 Device 005: ID 046d:c52b Logitech, Inc. Unifying Receiver
    Bus 001 Device 006: ID 0424:7800 Standard Microsystems Corp.
    Bus 001 Device 003: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
    Bus 001 Device 002: ID 0424:2514 Standard Microsystems Corp. USB 2.0 Hub
    pi@raspberrypi:~ $ lsusb -v -d 16c0:0483
    Device Descriptor:
      bLength                18
      bDescriptorType         1
      bcdUSB               1.10
      bDeviceSubClass         0
      bDeviceProtocol         0
      bMaxPacketSize0        64
      bcdDevice            2.77
      iSerial                 3 7183300
        bLength                 9
        bDescriptorType         2
        wTotalLength       0x0043
        bNumInterfaces          2
        iConfiguration          0
        bmAttributes         0xc0
          Self Powered
        MaxPower              100mA
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        0
          bAlternateSetting       0
          bNumEndpoints           1
          iInterface              0
          CDC Header:
            bcdCDC               1.10
            bmCapabilities       0x01
              call management
            bDataInterface          1
          CDC ACM:
            bmCapabilities       0x06
              sends break
          CDC Union:
            bMasterInterface        0
            bSlaveInterface         1
            bLength                 7
            bDescriptorType         5
            bmAttributes            3
              Synch Type               None
              Usage Type               Data
            bInterval              64
          bLength                 9
          bDescriptorType         4
          bInterfaceNumber        1
          bAlternateSetting       0
          bNumEndpoints           2
          iInterface              0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
            bLength                 7
            bDescriptorType         5
            bmAttributes            2
              Transfer Type            Bulk
              Synch Type               None
              Usage Type               Data
            bInterval               0
      (Bus Powered)
    To compare to yours, it looks like the only difference is in the "Device 009 vs Device 005" and "iSerial 3 2416110 vs iSerial 3 7183300".
    7,473
    As far as I can tell it is working fine for me.
    I ran your script on my RPI4 on a sketch slightly modified from yours:
      while (!Serial && millis() < 5000) ;
    uint32_t count = 0;
      Serial.println(count++);
    So that I could see if it continued or not...
    Here is about the 5th run of your script:
    pi@RPI4LSS:~ $ python test.py
    Script Started
    19052
    19053
    19054
    19055
    19056
    19057
    19058
    19059
    19060
    19061
    19062
    19063
    19064
    19065
    19066
    19067
    19068
    19069
    19070
    19071
    19072
    19073
    19074
    19075
    19076
    19077
    19078
    19079
    19080
    19081
    19082
    19083
    19084
    19085
    19086
    19087
    19088
    19089
    19090
    19091
    46240
    46241
    46242
    46243
    46244
    46245
    46246
    46247
    46248
    46249
    46250
    46251
    46252
    46253
    46254
    46255
    46256
    46257
    46258
    46259
    46260
    46261
    46262
    46263
    46264
    46265
    46266
    46267
    ^CTraceback (most recent call last):
      File "test.py", line 11, in <module>
      File "/usr/lib/python2.7/dist-packages/serial/serialposix.py", line 467, in in_waiting
        s = fcntl.ioctl(self.fd, TIOCINQ, TIOCM_zero_str)
    KeyboardInterrupt
    pi@RPI4LSS:~ $
    Some other things I would look at include:
    pi@RPI4LSS:~ $ ls -l /dev/ttyA*
    crw-rw-rw- 1 root dialout 166,  0 Jul 22 08:43 /dev/ttyACM0
    crw-rw---- 1 root dialout 204, 64 Jul 22 08:28 /dev/ttyAMA0
    pi@RPI4LSS:~ $ groups
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi
    pi@RPI4LSS:~ $
    Which the udev rules should have mostly handled anyway...
    But it shows that the ACM0 is in the dialout group. Also shows that my user (pi) is a member of the dialout group.
    But again warning I am not the biggest linux expert here. hopefully someone else will have some more suggestions.
    But if it is not working for you, it runs once and but not again, would wonder if maybe file (device) being left open?
    Not sure of best way to see if it is or not. My first guess at this may be something like:
    pi@RPI4LSS:~ $ lsof | grep /dev/tty
    bash       759                              pi    0u      CHR        4,1       0t0       1045 /dev/tty1
    bash       759                              pi    1u      CHR        4,1       0t0       1045 /dev/tty1
    bash       759                              pi    2u      CHR        4,1       0t0       1045 /dev/tty1
    bash       759                              pi  255u      CHR        4,1       0t0       1045 /dev/tty1
    python    2371                              pi    3u      CHR      166,0       0t0      26981 /dev/ttyACM0
