Results 1 to 3 of 3
Thread: Adafruit_gfx, Teensyduino 1.53, Teensy 3.2
    Oct 2016
    11
    Just updated Arduino 1.8.13 (from 1.8.4) and Teensyduino 1.53 (from 1.44) and found that "Adafruit_gfx" is missing.
    Does this have any particular reason?
    I copied "adafruit_gfx" from Teensyduino 1.44, now my sketch compiles again.
    23,487
    Adafruit_GFX was intentionally removed from 1.53, because the older copy we had was causing a lot of conflicts with several of Adafruit's libraries. Those conflicts have been an ongoing problem, so rather than update GFX again and (probably) have these problems return as Adafruit continues development of this library, I decided to remove it from the Teensyduino installer.
    The intended use is to install Adafruit_GFX using Arduino's library manager. In the beta testing for 1.53, we installed the latest Adafruit_GFX and checked it works with the remaining libs in Teensyduino which use it in some way.
    Oct 2016
    11
    Thanks for the quick reply.
    I have now installed it via the library manager. But it only works with older versions of adafruit_gfx (I think up to 1.5.x), with newer versions it hails error messages ... But the main thing is that it works. Will adjust my code if possible. Greetings from Austria.
