Results 1 to 3 of 3
Thread: ferrite bead teensy 3.x
    hi, I am working on a teensy 3.5 and is there any recommended dc resistance value and frequency for the 600 and 120 ferrite beads on the teensy 3.5?
    Apr 2019
    129
    It's odd that you are asking about the DC resistance. This is usually low around 1ohm and not really a significant factor (unless you're dealing with significant currents). You know that 600 and 120 refer to the impedance at 100MHz?
    https://datasheet.lcsc.com/szlcsc/Su...01TF_C1017.pdf
    May 2015
    USA
    845
    Depends on how much current you expect to draw - but matching the physical size and 100Mhz rating of the teensy ones is a reasonable choice.
    Physically larger sizes will provide more noise filtering with the same DC resistance. How important this is depends on the application.
