Results 1 to 4 of 4
Thread: Teensy 3.5 RTC problem
    Jul 2020
    2
    Hi
    I try to write a control program with a time code
    i want to write in the file and on screen the date and time (dd/mm/yyyy hh/mm/ss)
    i write this simple program:
    #include <TimeLib.h>
    // Variable Declaretion -----------------------------------------------------------
    //Time And Date Variables ---------------------------------------------------------
    String DandT;
    int Sec;
    int Mint;
    int Hr;
    int Dy;
    int Mnth;
    int Yr;
    String SSec;
    String SMint;
    String SHr;
    String SDy;
    String SMnth;
    String SYr;
    // Clock Setup Only For The First Time ---------------------------------------------
    setTime(22, 34, 25, 29, 3, 1982);
    // SetUp Time String For Display --------------------------------------------------
    Sec=int(second());
    Mint=int(minute());
    Hr=int(hour());
    Dy=int(day());
    Mnth=int(month());
    Yr=int(year());
    if (Sec<10){
    SSec="0"+String(Sec);
    }else{
    SSec=String(Sec);
    if (Mint<10){
    SMint="0"+String(Mint);
    }else{
    SMint=String(Mint);
    if (Hr<10){
    SHr="0"+String(Hr);
    }else{
    SHr=String(Hr);
    if (Dy<10){
    SDy="0"+String(Dy);
    }else{
    SDy=String(Dy);
    if (Mnth<10){
    SMnth="0"+String(Mnth);
    }else{
    SMnth=String(Mnth);
    SYr=String(Yr);
    DandT=(SDy+"/"+SMnth+"/"+SYr+" "+SHr+":"+SMint+":"+SSec);
    Serial.println (DandT);
    delay (500);
    time_t getTeensy3Time()
    return Teensy3Clock.get();
    A 3V battery is connected to the Vb pin and to the GND
    but when i delete the set time line it is always go back to 1.1.1970
    why?
    how can i keep the time from restarted again every time?
    thank you
    May 2017
    106
    you don't sync your timeLib with RTC of teensy, so TimeLib starts with zero UNIX time (1.1.1970).
    TimeLIB and RTC are two independend objects.
    To unterstand have look there https://forum.pjrc.com/threads/47988...?highlight=RTC , especialy posts of Paul Stofffregen there.
    Check also https://www.pjrc.com/teensy/td_libs_Time.html
    Jul 2020
    2
    Hi
    Thanks for the answering
    But I still do not understand/able to sync them to work properly
    When I run the teensy3 example the rtc is sync with my computer and run OK, i connect the battery and just can not syc it back
    (probably a noob problem)
    thanks for any one that solve this problem
    May 2017
    106
    You should post your source code and your serial monitor output here.
    Then its much easier to help.
