Hi, I'm new to using Teensy boards and I'm having issues with using Teensy 3.6 as an SPI slave.
I'm using an STM32 as Master and have checked SPI output with a logic analyser to make sure I'm sending the correct data (it's a simple string) and it's working fine.
The problem I have is that although data is being output on the serial monitor for the Teensy board, it only outputs 255.
I'm using the TSPISlave library found here:
https://github.com/tonton81/TSPISlave
I have checked the wiring (MOSI, SCK and CS (I'm not using MISO)) and they're all correct and I have a common ground for the two boards.
For me, it looks like the serial monitor is just displaying the clock.
Any help would really be apprciated.
