issue Using Pin Interrupt and I2C with Audio Library
prajtm
Hey everyone. I am trying to write a fairly basic synthesizer sketch for the Teensy 4.1 w/ Audio Shield but I've run into a hurdle that I would really appreciate some help with.
In the code (pasted below), I am receiving a byte of data, 'buttonStates' from a slave Arduino over I2C. The data received from the slave Arduino contains information about the binary states of several buttons. Currently, for testing, there are only 7 buttons so all this data fits into a single byte, but in the future i intend to have 40+ buttons/input devices. This receiving of this data is done inside a pin ISR (connected to a digital output on the slave Arduino), so that the Teensy can only request data from the slave Arduino when that Arduino has new set of data. This part of the code works fine by itself and I have tested it in a separate sketch.
Once this is received by the Teensy, I am trying to use that button information to control a simple string synthesizer created with the Audio System Design tool. Basically, If a button is pressed, (i.e. a 1 bit), I turn the corresponding string and envelope on, and once the button is release (i.e. a 0 bit) the corresponding envelope is turned off.
Also, I have an I2C OLED (SSD1306) connected which is working fine regardless.
This seems simple enough, but I'm having a lot of trouble getting it to all work together. Running the code below as it is causes the Teensy to crash (by crash, I mean no serial prints and not responding USB-based requests to enter program mode).
Here's what I've tried so far in terms of trying to debug it:
-If I just comment out the ISR stuff, I get the same crash result and no output.
-If I comment out the entire for loop containing the audio stuff, the program works fine and prints out the data received over I2C
-If I comment out the ISR stuff AND the lines
strs[i]->noteOn(keys[i],0.1);
if (!(envs[i]->isActive())){
  envs[i]->noteOn();
then the program works fine and prints out an output. Its pretty weird that this would have an effect because since all the bits in buttonStates are zero, the program shouldnt even enter the if statement where these functions are called.
-If I comment those lines out but leave in the pin_ISR() function with the attachInteerupt commented out I get the crash and no output. This is also really weird because in this case, pin_ISR() is never even getting called
-Interestingly, the OLED, whose text is only set in void setup(), works fine regardless of crashing. So I think that in the cases that the code is crashing, the program executes void setup() just fine but for some reason, gets held up at void loop().
So naturally I'm kinda perplexed and I would appreciate if anyone could offer any insight or suggestions to try out. Also this is my first forum post so i apologise in advance for any formatting/other mistakes. Thanks a lot! :)
Here's my code:
#include <Bounce.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET -1
Adafruit_SSD1306 display(128, 64, &Wire, OLED_RESET);
AudioSynthKarplusStrong  string2;        //xy=430.0000228881836,176.14286422729492
AudioSynthKarplusStrong  string3;        //xy=435.0000228881836,228.1428680419922
AudioSynthKarplusStrong  string7;        //xy=435.0000228881836,447.14287853240967
AudioSynthKarplusStrong  string5;        //xy=436.00005531311035,336.14290618896484
AudioSynthKarplusStrong  string1;        //xy=437.00004959106445,114.14286231994629
AudioSynthKarplusStrong  string4;        //xy=438.0000228881836,279.1428699493408
AudioSynthKarplusStrong  string6;        //xy=440.00005626678467,396.1429080963135
AudioEffectEnvelope      envelope6; //xy=585,399
AudioEffectEnvelope      envelope7; //xy=589,451
AudioEffectEnvelope      envelope2; //xy=593,172
AudioEffectEnvelope      envelope4; //xy=593,280
AudioEffectEnvelope      envelope1;      //xy=595.0000228881836,110.99999618530273
AudioEffectEnvelope      envelope3; //xy=596,227
AudioEffectEnvelope      envelope5; //xy=601.0000228881836,335.00001430511475
AudioMixer4              mixer1;         //xy=909.0000190734863,201.00000762939453
AudioMixer4              mixer2;         //xy=909.000072479248,360.2857360839844
AudioMixer4              mixer3;         //xy=1071.0000076293945,277.2857246398926
AudioOutputI2S           i2s1;           //xy=1461.0006675720215,278.2859001159668
AudioAnalyzePeak         peak1;          //xy=1465.428825378418,187.14288234710693
AudioConnection          patchCord1(string2, envelope2);
AudioConnection          patchCord2(string3, envelope3);
AudioConnection          patchCord3(string7, envelope7);
AudioConnection          patchCord4(string5, envelope5);
AudioConnection          patchCord5(string1, envelope1);
AudioConnection          patchCord6(string4, envelope4);
AudioConnection          patchCord7(string6, envelope6);
AudioConnection          patchCord8(envelope6, 0, mixer2, 1);
AudioConnection          patchCord9(envelope7, 0, mixer2, 2);
AudioConnection          patchCord10(envelope2, 0, mixer1, 1);
AudioConnection          patchCord11(envelope4, 0, mixer1, 3);
AudioConnection          patchCord12(envelope1, 0, mixer1, 0);
AudioConnection          patchCord13(envelope3, 0, mixer1, 2);
AudioConnection          patchCord14(envelope5, 0, mixer2, 0);
AudioConnection          patchCord15(mixer1, 0, mixer3, 0);
AudioConnection          patchCord16(mixer2, 0, mixer3, 1);
AudioConnection          patchCord17(mixer3, peak1);
AudioConnection          patchCord18(mixer3, 0, i2s1, 0);
AudioConnection          patchCord19(mixer3, 0, i2s1, 1);
AudioControlSGTL5000     sgtl5000_1;     //xy=64.5,20
AudioEffectEnvelope *envs[7] = {&envelope1, &envelope2, &envelope3, &envelope4, &envelope5, &envelope6, &envelope7};
AudioSynthKarplusStrong *strs[7] = {&string1, &string2, &string3, &string4, &string5, &string6, &string7};
float keys[7] = {27.50*3,30.87*3,32.70*3,36.71*3,41.20*3,43.65*3,49.00*3};
int numButtons = 7;
byte buttonStates = 0;
  attachInterrupt(34, pin_ISR, RISING);
  Wire.begin();
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  display.clearDisplay();
  display.setTextSize(3);      // Normal 1:1 pixel scale
  display.setTextColor(SSD1306_WHITE); // Draw white text
  display.setCursor(20, 25);     // Start at top-left corner
  display.println(F("HELLO"));
  display.drawRect(15, 20, 96, 30, SSD1306_WHITE);
  display.display();
  AudioMemory(18);
  sgtl5000_1.enable();
  sgtl5000_1.volume(1.0);
  for (int i=0; i<7; i++) {
    envs[i]->attack(90.2);
    envs[i]->hold(0);
    envs[i]->decay(31.4);
    envs[i]->sustain(0.6);
    envs[i]->release(440.5);
  AudioInterrupts();
for (int i = 0; i <= numButtons; i++){
  if (bitRead(buttonStates, i)){
    Serial.print(i);
    Serial.println(": on");
    AudioNoInterrupts();
      envs[i]->noteOn();
    AudioInterrupts();
  else{
    Serial.print(i);
    Serial.println(": off");
    envs[i]->noteOff();
  if (peak1.available()){
    float pk = peak1.read();
    pk=map(pk,0.01,0.1,0,128);
    display.fillRect(0, 30, pk, 10, SSD1306_WHITE);
    display.display();
void pin_ISR(){
    Wire.requestFrom(8, 1);
    while(Wire.available()) {
      Serial.print("read: ");
      buttonStates = Wire.read();
      Serial.print(buttonStates,BIN);
@prajtm:
I did not make a thorough study of everything that your sketch is doing, but I did notice that your loop makes 8 passes (0-7), where your arrays only have 7 members (0-6). As written, on the last pass thru your loop (when i=7), it seems that you will be accessing areas outside of your defined array bounds.
Mark J Culross
KD5RXT
@prajtm:
Mark J Culross
KD5RXT
You're right! I guess I hadn't noticed that lol. I switched the <= into < and it works great.
Thanks so much for spotting that
