Results 1 to 18 of 18
Thread: One Component on Teensy 4.1 gets very hot
    Aug 2020
    9
    Hi there,
    My teensy 4.1 used to work perfectly but, just now, when I plugged it in to the computer and tried to upload code I got the following error:
    No Teensy boards were found on any USB ports of your computer.
    I tried pushing the button, restarting my computer, and using a different usb cable. Nothing helped. I then noticed that one of the components on the board gets very hot very quickly when it is plugged in. Does that mean that the board is ruined beyond repair? I don't know which component is which. I am including a picture of which component is getting hot.
Name:	teensy board.jpg
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    330
    You may want to check out this thread.
    Most probably something [bad solderjoint?] is shorting the 3V3 output.
    Paul
    Aug 2020
    9
    Thank you so much for the quick response. I did not solder anything on the teensy board, and it worked well when I first bought it. How would I find a bad solderjoint? Is it possible to fix it or do I need a new board?
    Apr 2015
    Netherlands
    330
    First I would do a visual inspection using an optical magnifier. Check for loose/missing/shifted/misplaced components. Also check for tiny solderballs/metal particles anywhere that may short signal lines.
    Don't forget to check the bottom side as well.
    Then using a voltmeter, measure the actual voltage between the 3V3 pin [marked "3V" on the PCB] and GND pin.
    Paul
    Apr 2015
    Netherlands
    330
    Is it perhaps possible to send a close-up photo of your board?
    Paul
    Aug 2020
    9
Name:	teensy front.jpg
Name:	teensy zoomed in.jpg
    Apr 2015
    Netherlands
    330
    The little wire in the red circle is not supposed to be there:
    Paul
    Apr 2015
    Netherlands
    330
    Is the top of the package of the chip in the yellow circle nicely flat? It looks like a little bulge is sticking out. If so, then the regulator might be killed.
    Paul
    Aug 2020
    9
    Thank you for noticing that. I removed that wire and tried again. However, I am still having the same problem. The same component is getting hot and the computer cannot find the teensy. However, I am not noticing any bulge in component. Do you think it might be dead anyway? Is there a way to fix it?
    Apr 2015
    Netherlands
    330
    Before concluding that the regulator and/or board is killed, you could do 2 more tests:
    1. with the USB cable connected measure the voltage between the 3V3 pin [marked "3V" on the PCB] and GND pin. If it's not around 3V3, there is some short between these pins.
    2. without the USB cable or other power supply connected, measure the resistance between the 3V3 and GND pin. My Teensy 4.1 measures around 8.3KΩ.
    Paul
    Apr 2015
    Netherlands
    330
    Oops, sorry, I mixed up Teensy 3.2 and Teensy 4.1. The chip that is running hot is the MKL02Z32VFG4, the so-called Bootloader chip.
    That chip should not get hot as far as I know.
    Please forget the what I said and asked above.
    Not sure what to do next, perhaps replace the chip? But it would be sensible to get to the cause of running hot first.
    Paul
    Aug 2020
    9
    Would it make sense for me to mail the chip back to the factory then?
    Apr 2015
    Netherlands
    330
    The problem is that little wire that you removed from the board. That could have been around the board anywhere and may have shorted out some other lines with a failing board as result. Normally this is not covered by warranty. And as you stated in your first post, the board used to work perfectly...
    It happened to me long time ago with a non-Teensy board as well - also a little piece of wire/solderblob lying around the board. I just wrote the board off as my own error.
    Mailing the chip/board back to PJRC for repair is not economical I assume.
    Paul
    Aug 2020
    9
    If it is helpful, I just noticed a second component that is getting hot. It is circled on the pictureClick image for larger version.
    Apr 2015
    Netherlands
    330
    That's the DMG2305UX, a P-channel enhancement mode MOSFET that is setup to function as a low voltage drop diode. It carries the 5V USB voltage to the 3V3 regulator. That FET should not get hot at all.
    Hmm, I'm afraid the board is end-of-life...
    Paul
    23,012
    Very unusual for either of those 2 parts to get hot.
    Usually when things go wrong, the PTC fuse (small white part near the USB connector and 3V pin) gets hot. The voltage regulator (6 pin part just above the center pin of the USB host pins) also tends to get hot if something is shorting the 3.3V power. Those 2 parts are right next to the 2 parts you indicated as heating up....
    Jul 2020
    464
    Quote Originally Posted by PaulS View Post
    Paul
    To me "end of life" means "no longer manufactured". I'd just say the boards fried!
    [ To "end of life" in the industry means to set a schedule for the phasing out of a particular device's
    production. Often seen as "That part's been EOL'd". Before that, if you are lucky, you'll see "no longer
    recommended for new designs" slapped over datasheets and search results. ]
    Apr 2015
    Netherlands
    330
    I know EoL well, I should have said end-of-its-life... :-)
