Results 1 to 3 of 3
Thread: Upload program using serial port (Teensy 3.2)
    Aug 2020
    Germany
    3
    Hello everyone!
    I have Teensy 3.2 and need to upload the program directly from the PC via the serial port (TX, RX). I do not want to use the USB port of Teensy. Now I try TTL for it, but it is not working. Can you please give me any suggestions?
    Thanks in advance and have a nice day.
    Yours sincerely,
    Sandip
    22,663
    Sorry, programming by TTL level serial is not supported. USB is the only supported way.
    Aug 2020
    Germany
    3
    Thank you for your answer. Suppose my teensy is already programmed via USB and then I change some parameters in the program and I want to upload program in the same teensy without USB, then any other options are available or not?
    Thank you in advance.
