Results 1 to 5 of 5
Thread: Slow Teensy 3.2 12-bit DAC?
    Aug 2020
    5
    I'm looking at the DAC output on my scope and it looks janky.
    I'm using the audio library to run a sine wave at 5kHz:
    static int freq = 440;
    static int dir = 0;
    AudioSynthWaveform       waveform1;      //xy=220,160
    AudioOutputAnalog        dac1;           //xy=472,158
    AudioConnection          patchCord1(waveform1, dac1);
      analogWriteResolution(12);
      AudioMemory(10);
      waveform1.frequency(5000);
      waveform1.amplitude(1.0);
    ... but the scope is only showing about 9 level transitions per cycle. Using the scope's cursor, I can see that the level is updating about once every 23 microseconds. According to the chip's datasheet, the code-to-code settling time should be no longer than 1 microsecond (I know this isn't code-to-code, but it's pretty close). What am I doing wrong? I thought the DAC should be able to handle "audio-range" outputs quite happily but I'm failing down in the couple-of-kHz range.
    EDIT: I've just seen and tested the Hackaday article which runs the DAC at 100kHz using DMA, and it works a treat. Does the Audio library not use DMA?
    Jul 2020
    390
    Quote Originally Posted by commonbreed View Post
    Yes, that's expected. The Audio library handles signals at 44100 samples/second (23Ás). You
    need a reconstruction filter (aka anti-aliasing filter) on the output of the DAC with a cutoff
    frequency around 20kHz.
    Alternatively you'd need an output driver that does over-sampling at some multiple of 44.1kHz.
    Standard audio DACs with I2S interfaces do this all internally (the oversampling), requiring
    mininal external filtering.
    Aug 2020
    5
    Oh, of course! Thanks for pointing that out, of course I need a filter!
    Aug 2020
    5
    I'm thinking of using a MAX292 as a DAC post-filter, but it has some requirements that I'm not sure I can satisfy around clocking frequency:
    From the datasheet:
    DAC Post-Filtering
    When using the MAX291/MAX292/MAX295/MAX296 for
    DAC post-filtering, synchronize the DAC and the filter
    clocks. If clocks are not synchronized, beat frequencies will alias into the desired passband. The DAC’s
    clock should be generated by dividing down the
    switched-capacitor filter’s clock.
    I suppose the generation of this clock and subsequent supply to the Teensy might be difficult, or just not worthwhile? I want to stay away from I2S for my own experimentation purposes.
    Jul 2020
    390
    What maximum signal frequency are you interested in? A simple passive filter might be enough depending on where the signal
    goes (for instance human hearing acts as a low pass filter!).
