Hi guys,
I'm pretty sure i know the fault but not sure on the cause, just asking for theories. So I soldered wires to all of the GPIO's on the board, no wires to power solder points or programming/usb points. I connected the other end of the wires to a small pcb I have had fabricated but this board was unpowered so no excess voltage came from the board. Also checked all wires and points for short circuits, all ok.
The board worked once, so it allowed me to upload a sketch then died very quickly afterwards. The 3.3V point at the end of the board opposite the usb connector has 2ohm resistance to ground and the 3.3V point next to the usb connector is a dead short so I assume somehow the rail shorted. Now there's no possibility of 5V or higher being applied to any point on the board as there is no external voltage and the board was powered by the usb cable.
I did handle the board with my bare hand at one point trying to press the reset button and this is the only thing I could think of is perhaps shorting the 3.3V and GND at the end of the board with my thumb. Is this likely to be the cause do you think? To be fair, I really should have taken more care and do know better but was just being lazy.
Hope this all makes sense and am I right to assume the board is now useless?
