Results 1 to 14 of 14
Thread: Confused with the recommended circuitry for ADC on teensy.
    Hey. Quite a simple question. I found this on the teensy's Audio Library Design Tool documents.
    I *THINK* this is so that line level inputs are dc-offsetted appropriately so it can be read by an ADC within the range of 0 to 1.2v. i.e. adding 0.6v DC offset? am I correct? If I am, what exactly is that RC circuit doing? How were the values chosen? What do I search on google to learn more about this??
    and one more question,
    I hear that opamps can achieve DC offsetted output too. Is there any advantage of doing this with either the RC circuit or opamp that i'm missing? I'm asking because I do have some opamps lying around, but not those exact resistors and capacitors.
    Thank you guys always!
    You will have to ask the designer of the circuit to be sure, but it looks to me like it is an RC bandpass filter, in addition to providing bias.
    Jul 2020
    398
    Quote Originally Posted by jidagraphy View Post
    Yes, there's a virtual ground at 0.6V comprising the 10k, 2k2, 10uF to ground. The capacitor makes this
    this virtual ground referenced to real ground at audio frequencies (ie it suppresses all the digital hash
    on the 3.3V rail).
    The other series capacitor (only needs to be about 470nF, 10F is overkill), is a DC blocker.
    The cutoff freq of 10F into 47k load is 10 * 47k = 0.47s, corresponding to 0.3Hz. 470nF gives
    a more rational 22ms and 7Hz.
    The input 47k can be much larger (1M), it serves only to discharge the series capacitor when
    nothing's plugged in, so there isn't an almighty full-scale *CRACK* when you do plug something in.
    The values weren't really chosen particularly carefully, but they will work. Normally audio input
    impedance is 47k (although in modern equipment is often less, such as 10k, since valve circuitry
    isn't used any more(!)).
    Opamps can buffer (lower the impedance) and amplify (raise the signal level). Passive networks can't amplify, and can
    only lower the impedance through attenuation (which raises the noise floor).
    You'll need the resistors and capacitors with an opamp too though.
    May 2015
    USA
    642
    Maybe you don't want to go quite this far, but a great way to learn about circuits is to type them into LTSpice and and try things and see the result.
    on the 3.3V rail).
    This is GOLD. Dont understand much of it except the input 47k, but this will be a nice starting point. Thank you always MarkT!
    Do you have any suggestions on what I should google regarding this topic of DC offsetting with RC circuits and opamps? What is this circuit even called?
    oh wow is this some sort of circuit simulator?? this would be very useful!
    Thanks!
    on the 3.3V rail).
    Hey just a question.
    Is this circuit making any assumptions? i.e. the input audio outputs voltage in the range of ___v?
    I was looking at the circuit and I realised the DC offset wouldnt work if the audio voltage spans wider than 0.6v, am I right?
    What should I expect from a typical consumer audio devices like synthesizers?
    2,754
    only assumption: input signal is <0.6 V. possible DC-offset is taken care by AC coupling
    Hi MarkT,
    Sorry for bringing this up again, I just couldnt find an answer.
    I just have a few questions
    What do you mean by :
    on the 3.3V rail).
    Because the circuit works and gives +0.6v dc offset whether that particular capacitor is there or not.
    What does it mean by "digital hash?"
    Also,
    I understand the role of a DC blocker, yet I didn't understand why 470nF would be more Ideal.
    and lastly,
    the circuit seemse to work without a lot of the components mentioned in the diagram. Some I understand, some I dont. The DC offset seems to work with a simple voltage divider that brings down 3.3v to 0.6v, joined with an audio signal and a capacitor in series. Not fully understanding the questions above, I feel like my bare minimum does the job. How would this set up affect the audio?
    Thank you MarkT! Your help is always appreciated!
    Senior Member Jp3141's Avatar
    486
    Be careful -- a very large DC offset on the input (say 5 V) could damage the Teensy when it is initially plugged in because the initial step as the 10 uF is charged will be driven straight into the A2 pin. If this is a possibility, put a 1k resistor in series with that 10 uF.
    Oh yes! thanks for clarifying!
    Quote Originally Posted by Jp3141 View Post
    Do you mean like this spike? (0.3v AC with 3v DC offset).
Name:	Screenshot 2020-08-21 at 2.28.17 PM.jpg
    Jul 2020
    398
    There's no 1k resistor in series with the input in that circuit.
    486
    Yes, that spike could be bad. Add 1k in series with the input, or just in series with the 10 uF.
    You don't need to use 1k & 220 Ω -- they make the cutoff frequency too high for audio (10 uF & (220//1k) = 10u&180 = 88 Hz; They also set the bias point unnecessarily low (around 0.6 V) -- so just use 10k (or even 100k) resistors for each to set the boas point around 1.6 V. With 0.6 V bias, your ADC will clip for signals over 0.6 V peak; with mid-rail bias, you can handle 1.6 V AC peaks.
    The original circuit had a 47k from the R divider tap to the bias point -- that allowed another 10 uF (could have used 0.1 uF) to filter any noise coming in from the 3.3 V supply. How important this depends on the signal quality you expect.
    Feb 2018
    Corvallis, OR
    205
    Since the original photo showed a T3.2, perhaps the user intended to use the ADC with the internal 1.2V reference. In that case, 0.6V is the midpoint of the ADC range.
