Results 1 to 1 of 1
Thread: How could I use an array in the audio synthesis Guitar example?
    Jun 2020
    7
    Although I am a slow learner, I'm teaching myself coding using YouTube and Google, and also by trying to understand code that looks interesting and seeing if I can learn about it and edit it.
    In the audio library examples sketches is a really interesting synthesis example called "Guitar" some of which I understand and some of which is new.
    As I understand it, the sketch uses *chord to reference chords.h which constructs the 6 six string chords of the guitar from a table of notes. I've attached Guitar.ino sketch and chords.h.
    There is a series of 'if else' statements which loop to play the chords. So far so good and the sound is great.
    Meanwhile I have been teaching myself about arrays and I thought - well I wonder whether I could declare an array of chords and then use a 'for loop' to go through them instead of using the 'if else' approach in the original sketch. It would then be a bit easier to populate the chords in the array to play different songs.
    Something like...
    HTML Code:
    data type? chordArray []=(Aminor, Dminor, Cmajor, Emajor};
    for (int = 0; i<4;i++)
    chord = chordArray(i);
    strum_up(chord, 1.0);
    delay(hand_delay);
    What I am puzzled about is how to declare the array's data type. It isn't an int, a float, nor a string and I'm stuck at this point.
    In my reading I can see that people advise that working with pointers is not for beginners and so I think I may be trying to run before I can walk but any advice to help me get to the next step would be very welcome.
    Thanks in advance.
    Robert
    Guitar.ino
    #include "chords.h"
    // Special thanks to Matthew Rahtz - http://amid.fish/karplus-strong/
    AudioSynthKarplusStrong  string1;
    AudioSynthKarplusStrong  string2;
    AudioSynthKarplusStrong  string3;
    AudioSynthKarplusStrong  string4;
    AudioSynthKarplusStrong  string5;
    AudioSynthKarplusStrong  string6;
    AudioMixer4              mixer1;
    AudioMixer4              mixer2;
    AudioOutputI2S           i2s1;
    AudioConnection          patchCord1(string1, 0, mixer1, 0);
    AudioConnection          patchCord2(string2, 0, mixer1, 1);
    AudioConnection          patchCord3(string3, 0, mixer1, 2);
    AudioConnection          patchCord4(string4, 0, mixer1, 3);
    AudioConnection          patchCord5(mixer1, 0, mixer2, 0);
    AudioConnection          patchCord6(string5, 0, mixer2, 1);
    AudioConnection          patchCord7(string6, 0, mixer2, 2);
    AudioConnection          patchCord8(mixer2, 0, i2s1, 0);
    AudioConnection          patchCord9(mixer2, 0, i2s1, 1);
    AudioControlSGTL5000     sgtl5000_1;
    const int finger_delay = 5;
    const int hand_delay = 220;
    int chordnum=0;
      AudioMemory(15);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.6);
      mixer1.gain(0, 0.15);
      mixer1.gain(1, 0.15);
      mixer1.gain(2, 0.15);
      mixer1.gain(3, 0.15);
      mixer2.gain(1, 0.15);
      mixer2.gain(2, 0.15);
      delay(700);
    void strum_up(const float *chord, float velocity);
    void strum_dn(const float *chord, float velocity);
      const float *chord;
      // each time through the loop, play a different chord
      if (chordnum == 0) {
        chord = Cmajor;
        Serial.println("C major");
        chordnum = 1;
      } else if (chordnum == 1) {
        chord = Gmajor;
        Serial.println("G major");
        chordnum = 2;
      } else if (chordnum == 2) {
        chord = Aminor;
        Serial.println("A minor");
        chordnum = 3;
        chord = Eminor;
        Serial.println("E minor");
        chordnum = 0;
      // then strum the 6 string several times
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      strum_dn(chord, 0.8);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      strum_dn(chord, 0.7);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      delay(hand_delay);
      Serial.print("Max CPU Usage = ");
      Serial.print(AudioProcessorUsageMax(), 1);
      Serial.println("%");
      if (chord[0] > 20.0) string1.noteOn(chord[0], velocity);
      delay(finger_delay);
      if (chord[1] > 20.0) string2.noteOn(chord[1], velocity);
      if (chord[2] > 20.0) string3.noteOn(chord[2], velocity);
      if (chord[3] > 20.0) string4.noteOn(chord[3], velocity);
      if (chord[4] > 20.0) string5.noteOn(chord[4], velocity);
      if (chord[5] > 20.0) string6.noteOn(chord[5], velocity);
      if (chord[5] > 20.0) string1.noteOn(chord[5], velocity);
      if (chord[4] > 20.0) string2.noteOn(chord[4], velocity);
      if (chord[3] > 20.0) string3.noteOn(chord[3], velocity);
      if (chord[2] > 20.0) string4.noteOn(chord[2], velocity);
      if (chord[1] > 20.0) string5.noteOn(chord[1], velocity);
      if (chord[0] > 20.0) string6.noteOn(chord[0], velocity);
    chords.h
    #define NOTE_E2   82.41
    #define NOTE_F2   87.31
    #define NOTE_Fs2  92.50
    #define NOTE_G2   98.00
    #define NOTE_Gs2 103.82
    #define NOTE_A2  110.00
    #define NOTE_As2 116.54
    #define NOTE_B2  123.47
    #define NOTE_C3  130.81
    #define NOTE_Cs3 138.59
    #define NOTE_D3  146.83
    #define NOTE_Ds3 155.56
    #define NOTE_E3  164.81
    #define NOTE_F3  174.61
    #define NOTE_Fs3 185.00
    #define NOTE_G3  196.00
    #define NOTE_Gs3 207.65
    #define NOTE_A3  220.00
    #define NOTE_As3 233.08
    #define NOTE_B3  246.94
    #define NOTE_C4  261.63
    #define NOTE_Cs4 277.18
    #define NOTE_D4  293.66
    #define NOTE_Ds4 311.13
    #define NOTE_E4  329.63
    #define NOTE_F4  349.23
    #define NOTE_Fs4 369.99
    #define NOTE_G4  392.00
    #define NOTE_Gs4 415.30
    #define NOTE_A4  440.00
    #define NOTE_As4 466.16
    #define NOTE_B4  493.88
    // The equation for note to frequency is:
    // float freq = 440.0f * exp2f((float)(note - 69) * 0.0833333f);
    // according to http://www.guitar-chords.org.uk/
    // and http://www.8notes.com/guitar_chord_chart/c.asp
                  // open =  NOTE_E2  NOTE_A2  NOTE_D3  NOTE_G3  NOTE_B3  NOTE_E4
    const float Cmajor[6] = {      0, NOTE_C3, NOTE_E3, NOTE_G3, NOTE_C4, NOTE_E4};  // C - E - G
    const float Dmajor[6] = {      0,       0, NOTE_D3, NOTE_A3, NOTE_D4, NOTE_Fs4}; // D - F# - A
    const float Emajor[6] = {NOTE_E2, NOTE_B2, NOTE_E3, NOTE_Gs3,NOTE_B3, NOTE_E4};  // E - G# - B
    const float Fmajor[6] = {      0, NOTE_A2, NOTE_F3, NOTE_A3, NOTE_C4, NOTE_F4};  // F - A - C
    const float Gmajor[6] = {NOTE_G2, NOTE_B2, NOTE_D3, NOTE_G3, NOTE_B3, NOTE_E4};  // G - B - D
    const float Amajor[6] = {      0, NOTE_A2, NOTE_E3, NOTE_A3, NOTE_Cs4,NOTE_E4};  // A - C# - E
    const float Bmajor[6] = {      0, NOTE_B2, NOTE_Fs3,NOTE_B3, NOTE_Ds4,NOTE_Fs4}; // B - D# - F#
    const float Cminor[6] = {      0, NOTE_C3, NOTE_G3, NOTE_C4, NOTE_Ds4,NOTE_G4};  // C - D# - G
    const float Dminor[6] = {      0,       0, NOTE_D3, NOTE_A3, NOTE_D4, NOTE_F4};  // D - F - A
    const float Eminor[6] = {NOTE_E2, NOTE_B2, NOTE_E3, NOTE_G3, NOTE_B3, NOTE_E4};  // E - G - B
    const float Fminor[6] = {NOTE_F2, NOTE_C3, NOTE_F3, NOTE_Gs3,NOTE_C4, NOTE_F4};  // F - G# - C
    const float Gminor[6] = {NOTE_G2, NOTE_D3, NOTE_G3, NOTE_As3,NOTE_D3, NOTE_G4};  // G - A# - D
    const float Aminor[6] = {      0, NOTE_A2, NOTE_E3, NOTE_A3, NOTE_C4, NOTE_E4};  // A - C - E
    const float Bminor[6] = {      0, NOTE_B2, NOTE_Fs3,NOTE_B3, NOTE_D4, NOTE_Fs4}; // B - D - F#
    //                   E2, F2, F2#, G2, G2#, A2, A2#, B2
    // C3, C3#, D3, D3#, E3, F3, F3#, G3, G3#, A3, A3#, B3
    // C4, C4#, D4, D4#, E4, F4, F4#, G4, G4#, A4, A4#, B4
    Attached Files Attached Files
