Results 1 to 6 of 6
Thread: Teensy 4.1 VBAT pins
    Anyone who can help,
    Can anyone help me identify the correct pins on the Teensy 4.1 to which a battery should be connected for the RTC to continue to function?
    There's no indication on the pin-out diagram.
    Many thanks,
    Allen
    Hi Manitou,
    Many thanks for your quick response, and I have looked through that posting, but cannot see any pins labelled 'VBat'.
    Is there something that I should be looking for?
    I appreciate your help,
    Best wishes,
    Allen
    Feb 2020
    South Africa
    35
    The holes next to the micro-SD card reader, are in the same order as the Teensy 4.0, but in a different location. Going from top to bottom on the above picture of the back side, the pins are:
    Pin 38 on the outer row
    On/off
    Program
    Ground
    3.3v
    Vbat
    Pin 27 on the outer row
    12,238
    Quote Originally Posted by AllenCherry View Post
    Hi Manitou,
    Best wishes,
    Allen
    They are identical in order to the T_4.0, just shifted over to accommodate the parts and match the T_3.6 form factor. As @Saibot notes they are called out lower in the text linked by @Manitou.
    Ah!!
    Many thanks - all becomes clear now!
    Sorry to be such an idiot!
    Thank you all for your patience,
    Allen
