Hi there, I'm having a really tough time getting these encoder boards to work with my Teensy 3.6.
I use the example code they provide and it works fine on my Arduino UNO, but when I try to move it to my Teensy, it just doesn't work. The serial monitor just gets a constant loop of:
I'm trying to use the encoder in a more complicated project, but to try and troubleshoot, I'm just using the example code — still not getting anywhere.
I've got SCL plugged into A5, SDA into A4 and int into A3, so I figure I'm using the first i2c bus (Wire), but I'm just not getting anywhere. Here's the example code I'm using that work on the UNO but not the Teensy.
Anyone have an ideas? I'm stumped, with my admittedly, very limited knowledge of this stuff.
Increment: -1
Decrement: -1
Maximum threshold: -1
Minimum threshold: -1
Push button Released
Push button Pressed
Double push!
#include <i2cEncoderLibV2.h>
/*This is a basic example for using the I2C Encoder V2
The counter is set to work between +10 to -10, at every encoder click the counter value is printed on the terminal.
It's also printet when the push button is pressed, or released or double pushed.
Connections with Arduino UNO:
- -> GND
+ -> 5V
SDA -> A4
SCL -> A5
INT -> A3
const int IntPin = A3; /* Definition of the interrupt pin. You can change according to your board /*
//Class initialization with the I2C addresses*/
i2cEncoderLibV2 Encoder(0x01); /* A0 is soldered */
void setup(void) {
pinMode(IntPin, INPUT);
Wire.begin();
Serial.println("**** I2C Encoder V2 basic example ****");
INT_DATA= The register are considered integer.
WRAP_DISABLE= The WRAP option is disabled
DIRE_LEFT= Encoder left direction increase the value
IPUP_ENABLE= INT pin have the pull-up enabled.
RMOD_X1= Encoder configured as X1.
RGB_ENCODER= type of encoder is RGB, change to STD_ENCODER in case you are using a normal rotary encoder.wir
Encoder.reset();
Encoder.begin(
i2cEncoderLibV2::INT_DATA | i2cEncoderLibV2::WRAP_DISABLE
| i2cEncoderLibV2::DIRE_LEFT | i2cEncoderLibV2::IPUP_ENABLE
| i2cEncoderLibV2::RMOD_X1 | i2cEncoderLibV2::RGB_ENCODER);
// Use this in case of standard encoder!
// Encoder.begin(i2cEncoderLibV2::INT_DATA | i2cEncoderLibV2::WRAP_DISABLE | i2cEncoderLibV2::DIRE_LEFT | i2cEncoderLibV2::IPUP_ENABLE | i2cEncoderLibV2::RMOD_X1 | i2cEncoderLibV2::STD_ENCODER);
// try also this!
// Encoder.begin(i2cEncoderLibV2::INT_DATA | i2cEncoderLibV2::WRAP_ENABLE | i2cEncoderLibV2::DIRE_LEFT | i2cEncoderLibV2::IPUP_ENABLE | i2cEncoderLibV2::RMOD_X1 | i2cEncoderLibV2::RGB_ENCODER);
Encoder.writeCounter((int32_t) 0); /* Reset the counter value */
Encoder.writeMax((int32_t) 10); /* Set the maximum threshold*/
Encoder.writeMin((int32_t) - 10); /* Set the minimum threshold */
Encoder.writeStep((int32_t) 1); /* Set the step to 1*/
Encoder.writeInterruptConfig(0xff); /* Enable all the interrupt */
Encoder.writeAntibouncingPeriod(20); /* Set an anti-bouncing of 200ms */
Encoder.writeDoublePushPeriod(50); /*Set a period for the double push of 500ms */
if (digitalRead(IntPin) == LOW) {
if (Encoder.updateStatus()) {
if (Encoder.readStatus(i2cEncoderLibV2::RINC)) {
Serial.print("Increment: ");
Serial.println(Encoder.readCounterByte());
/* Write here your code */
if (Encoder.readStatus(i2cEncoderLibV2::RDEC)) {
Serial.print("Decrement: ");
if (Encoder.readStatus(i2cEncoderLibV2::RMAX)) {
Serial.print("Maximum threshold: ");
if (Encoder.readStatus(i2cEncoderLibV2::RMIN)) {
Serial.print("Minimum threshold: ");
if (Encoder.readStatus(i2cEncoderLibV2::PUSHR)) {
Serial.println("Push button Released");
if (Encoder.readStatus(i2cEncoderLibV2::PUSHP)) {
Serial.println("Push button Pressed");
if (Encoder.readStatus(i2cEncoderLibV2::PUSHD)) {
Serial.println("Double push!");
