Processors not on a board
Fluxanode
Paul:
Can one purchase from you the MK20DX256VLH7 microprocessor used in the Teensy3.2 (or any of the other MPs) programed with the arduino bootloader to use in my own designs?
The main CPU is not where the bootloader code resides, it is in the separate bootloader IC available: https://www.pjrc.com/store/ic_mkl02.html
If doing a custom design, see notes at the bottom of the thread and more recent forum threads on some of the gotchas is this sort of thing.
And yes, if you are really confident that your design will never need new firmware it is possible to put a bootloader on some sort of programing module and just use it to program the entire production run.
