SPI.transfer() Hangs on in the first call using Teensy 4.0 and CC1101
Greetings to all!
I have been trying to use the cc1101 module of texas instrument with my Teensy 4.0 through SPI, I have been based on the library proposed by ELECHOUSE
[https://github.com/simonmonk/CC1101_arduino]
I have read the instructions that you leave about the SPI library [https://www.pjrc.com/teensy/td_libs_SPI.html]
Because of this I know that I have to use the methods:
-SPI.beginTransaction ()
-SPI.transfer ()
-SPI.endTransaction ()
So I changed some lines from the ELECHOUSE library as I show below:
Transmitter code on Arduino:
#include <ELECHOUSE_CC1101.h>
#define size 2 //tamanio de buffer a mandar
const long int sgn = 32768;  //0x8000; // B1000000000000000;// numero negativo
long int Byte1 = 0, Byte2 = 0;
byte data_Tx[size] = {0};
int tiempo = 20;
unsigned long timenow;
byte TX_buffer[size] = {0}; //inicializar
byte i;
//int x=0;
int x, y, z;
  pinMode(8,OUTPUT); // debugger
  delay(1);
  ELECHOUSE_cc1101.Init();
  //Serial.println("Transmisor:");
  Serial.println("EMPEZO");
  x = -90;
  Serial.println(x);
  if (x < 0) {
    x = (-1 * (x)) + sgn; // coloca el signo en el bit mas significativo
  Byte1 = x & 255;//enmascaramiento de BYTE inferior
  Byte2 = x & 65280; // enmascaramiento de BYTE superior
  Byte2 = Byte2 >> 8; // haz un bitshift left de 8 posiciones para derechaM
  data_Tx[0] = Byte1;//inferior
  data_Tx[1] = Byte2;//superior
  ELECHOUSE_cc1101.SendData(data_Tx, size);
Modified ELECHOUSE Library:
	This library was originally copyright of Michael at elechouse.com but permision was
    granted by Wilson Shen on 2016-10-23 for me (Simon Monk) to uodate the code for Arduino 1.0+
    and release the code on github under the MIT license.
Wilson Shen <elechouse@elechouse.com>	23 October 2016 at 02:08
To: Simon Monk
Thanks for your email.
You are free to put it in github and to do and change.
On Oct 22, 2016 10:07 PM, "Simon Monk" <srmonk@gmail.com> wrote:
	I'm Simon Monk, I'm currently writing the Electronics Cookbook for O'Reilly. I use your
	ELECHOUSE_CC1101 library in a 'recipe'. Your library is by far the easiest to use of
	the libraries for this device, but the .h and .cpp file both reference WProgram.h which
	as replaced by Arduino.h in Arduino 1.0.
	Rather than have to talk my readers through applying a fix to your library, I'd like
	your permission to put the modified lib into Github and add an example from the book.
	I would of course provide a link to your website in the book and mention that you can buy
	the modules there. If its ok, I'd give the code an MIT OS license, to clarify its use.
	Thanks for a great library,
	Kind Regards,
	Simon Monk.
#include <Arduino.h>
#include <SPI.h> // For SPI functions
#define 	WRITE_BURST     	0x40						//write burst
#define 	READ_SINGLE     	0x80						//read single
#define 	READ_BURST      	0xC0						//read burst
#define 	BYTES_IN_RXFIFO     0x7F  						//byte number in RXfifo
byte PaTabel[8] = {0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60 ,0x60};
// byte PaTabel[8] = {0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0 ,0xC0};
*FUNCTION NAME:SpiInit
*FUNCTION     :spi communication initialization
*INPUT        :none
*OUTPUT       :none
void ELECHOUSE_CC1101::SpiInit(void)
	// initialize the SPI pins
	SPI.begin(); //
	pinMode(SCK_PIN, OUTPUT);
	pinMode(MOSI_PIN, OUTPUT);
	pinMode(MISO_PIN, INPUT);
	pinMode(SS_PIN, OUTPUT);
	//Serial.println("SpiInit-CHECK");
	// digitalWrite(8,1);
	// enable SPI Master, MSB, SPI mode 0, FOSC/4
	//SpiMode(0);
*FUNCTION NAME:SpiMode
*FUNCTION     :set spi mode
*INPUT        :        config               mode
			   (0<<CPOL) | (0 << CPHA)		 0
			   (0<<CPOL) | (1 << CPHA)		 1
			   (1<<CPOL) | (0 << CPHA)		 2
			   (1<<CPOL) | (1 << CPHA)		 3
*OUTPUT       :none
void ELECHOUSE_CC1101::SpiMode(byte config)
	byte tmp;
	// enable SPI master with configuration byte specified
	SPCR = 0;
	SPCR = (config & 0x7F) | (1<<SPE) | (1<<MSTR);
	tmp = SPSR;
	tmp = SPDR;
*FUNCTION NAME:SpiTransfer
*FUNCTION     :spi transfer
*INPUT        :value: data to send
*OUTPUT       :data to receive
byte ELECHOUSE_CC1101::SpiTransfer(byte value)
	SPDR = value;
	while (!(SPSR & (1<<SPIF))) ;
	return SPDR;
*FUNCTION NAME: GDO_Set()
*FUNCTION     : set GDO0,GDO2 pin
*INPUT        : none
*OUTPUT       : none
void ELECHOUSE_CC1101::GDO_Set (void)
	pinMode(GDO0, INPUT);
	pinMode(GDO2, INPUT);
	//Serial.println("GDO_Set-CHECK");
*FUNCTION NAME:Reset
*FUNCTION     :CC1101 reset //details refer datasheet of CC1101/CC1100//
*INPUT        :none
*OUTPUT       :none
void ELECHOUSE_CC1101::Reset (void)
	//digitalWrite(8,1);
	digitalWrite(SS_PIN, LOW);
	delay(1);
	digitalWrite(SS_PIN, HIGH);
	delay(1);
	SPI.beginTransaction(SPISettings(4000000, MSBFIRST, SPI_MODE0)); //
	//delayMicroseconds(2);          // delay doesn't work
	while(digitalRead(MISO_PIN));
	//digitalWrite(8,1);          //Just for debugging purposes
	SPI.transfer(CC1101_SRES);//SpiTransfer(CC1101_SRES);                    // STUCK IN HERE
	SPI.endTransaction(); //
	//Serial.println("Reset-CHECK");
*FUNCTION NAME:Init
*FUNCTION     :CC1101 initialization
*INPUT        :none
*OUTPUT       :none
void ELECHOUSE_CC1101::Init(void)
	SpiInit();						//spi initialization
	GDO_Set();						//GDO set
	digitalWrite(SCK_PIN, HIGH);
	digitalWrite(MOSI_PIN, LOW);
	Reset();						//CC1101 reset
	RegConfigSettings(F_433);				//CC1101 register config
	SpiWriteBurstReg(CC1101_PATABLE,PaTabel,8);		//CC1101 PATABLE config
*FUNCTION NAME:Init
*INPUT        :none
*OUTPUT       :none
void ELECHOUSE_CC1101::Init(byte f)
	RegConfigSettings(f);					//CC1101 register config
*FUNCTION NAME:SpiWriteReg
*FUNCTION     :CC1101 write data to register
*INPUT        :addr: register address; value: register value
*OUTPUT       :none
void ELECHOUSE_CC1101::SpiWriteReg(byte addr, byte value)
	SPI.transfer(addr); // SpiTransfer(addr);
	SPI.transfer(value); // SpiTransfer(value);
*FUNCTION NAME:SpiWriteBurstReg
*FUNCTION     :CC1101 write burst data to register
*INPUT        :addr: register address; buffer:register value array; num:number to write
*OUTPUT       :none
void ELECHOUSE_CC1101::SpiWriteBurstReg(byte addr, byte *buffer, byte num)
	byte i, temp;
	temp = addr | WRITE_BURST;
    	SPI.transfer(temp); //SpiTransfer(temp);
    	for (i = 0; i < num; i++)
        	SPI.transfer(buffer[i]);//SpiTransfer(buffer[i]);
	// Serial.println("SpiWriteBurstReg-CHECK"); // NO PONERLO PORQUE DESEQUILIBRA LOS TIEMPOS
*FUNCTION NAME:SpiStrobe
*FUNCTION     :CC1101 Strobe
*INPUT        :strobe: command; //refer define in CC1101.h//
*OUTPUT       :none
void ELECHOUSE_CC1101::SpiStrobe(byte strobe)
	SPI.transfer(strobe); //SpiTransfer(strobe);
	// Serial.println("SpiStrobe-CHECK");
*FUNCTION NAME:SpiReadReg
*FUNCTION     :CC1101 read data from register
*OUTPUT       :register value
byte ELECHOUSE_CC1101::SpiReadReg(byte addr)
	byte temp, value;
    	temp = addr|READ_SINGLE;
	value = SPI.transfer(0); //SpiTransfer(0);
	return value;
*FUNCTION NAME:SpiReadBurstReg
*FUNCTION     :CC1101 read burst data from register
*INPUT        :addr: register address; buffer:array to store register value; num: number to read
*OUTPUT       :none
void ELECHOUSE_CC1101::SpiReadBurstReg(byte addr, byte *buffer, byte num)
	byte i,temp;
	temp = addr | READ_BURST;
	for(i=0;i<num;i++)
		buffer[i]=SPI.transfer(0); //SpiTransfer(0);
*FUNCTION NAME:SpiReadStatus
*FUNCTION     :CC1101 read status register
*OUTPUT       :status value
byte ELECHOUSE_CC1101::SpiReadStatus(byte addr)
	byte value,temp;
	return value;
*FUNCTION NAME:RegConfigSettings
*FUNCTION     :CC1101 register config //details refer datasheet of CC1101/CC1100//
*INPUT        :none
*OUTPUT       :none
void ELECHOUSE_CC1101::RegConfigSettings(byte f)
	SpiWriteReg(CC1101_FSCTRL1,  0x08);
	SpiWriteReg(CC1101_FSCTRL0,  0x00);
	switch(f)
		case F_868:
			SpiWriteReg(CC1101_FREQ2,    F2_868);
			SpiWriteReg(CC1101_FREQ1,    F1_868);
			SpiWriteReg(CC1101_FREQ0,    F0_868);
		case F_902:
			SpiWriteReg(CC1101_FREQ2,    F2_902);
			SpiWriteReg(CC1101_FREQ1,    F1_902);
			SpiWriteReg(CC1101_FREQ0,    F0_902);
		case F_433:
			SpiWriteReg(CC1101_FREQ2,    F2_433);
			SpiWriteReg(CC1101_FREQ1,    F1_433);
			SpiWriteReg(CC1101_FREQ0,    F0_433);
		default: // F must be set
	SpiWriteReg(CC1101_MDMCFG4,  0x5B);
	SpiWriteReg(CC1101_MDMCFG3,  0xF8);
	SpiWriteReg(CC1101_MDMCFG2,  0x03);
	SpiWriteReg(CC1101_MDMCFG1,  0x22);
	SpiWriteReg(CC1101_MDMCFG0,  0xF8);
	SpiWriteReg(CC1101_CHANNR,   0x00);
	SpiWriteReg(CC1101_DEVIATN,  0x47);
	SpiWriteReg(CC1101_FREND1,   0xB6);
	SpiWriteReg(CC1101_FREND0,   0x10);
	SpiWriteReg(CC1101_MCSM0 ,   0x18);
	SpiWriteReg(CC1101_FOCCFG,   0x1D);
	SpiWriteReg(CC1101_BSCFG,    0x1C);
	SpiWriteReg(CC1101_AGCCTRL2, 0xC7);
	SpiWriteReg(CC1101_AGCCTRL1, 0x00);
	SpiWriteReg(CC1101_AGCCTRL0, 0xB2);
	SpiWriteReg(CC1101_FSCAL3,   0xEA);
	SpiWriteReg(CC1101_FSCAL2,   0x2A);
	SpiWriteReg(CC1101_FSCAL1,   0x00);
	SpiWriteReg(CC1101_FSCAL0,   0x11);
	SpiWriteReg(CC1101_FSTEST,   0x59);
	SpiWriteReg(CC1101_TEST2,    0x81);
	SpiWriteReg(CC1101_TEST1,    0x35);
	SpiWriteReg(CC1101_TEST0,    0x09);
	SpiWriteReg(CC1101_IOCFG2,   0x0B); 	//serial clock.synchronous to the data in synchronous serial mode
	SpiWriteReg(CC1101_IOCFG0,   0x06);  	//asserts when sync word has been sent/received, and de-asserts at the end of the packet
	SpiWriteReg(CC1101_PKTCTRL1, 0x04);	//two status bytes will be appended to the payload of the packet,including RSSI LQI and CRC OK
							//No address check
	SpiWriteReg(CC1101_PKTCTRL0, 0x05);	//whitening off;CRC Enable\A3\BBvariable length packets, packet length configured by the first byte after sync word
	SpiWriteReg(CC1101_ADDR,     0x00);	//address used for packet filtration.
	SpiWriteReg(CC1101_PKTLEN,   0x3D); 	//61 bytes max length
	Serial.println("RegConfigSettings-CHECK");
*FUNCTION NAME:SendData
*FUNCTION     :use CC1101 send data
*INPUT        :txBuffer: data array to send; size: number of data to send, no more than 61
*OUTPUT       :none
void ELECHOUSE_CC1101::SendData(byte *txBuffer,byte size)
	SpiWriteReg(CC1101_TXFIFO,size);
	SpiWriteBurstReg(CC1101_TXFIFO,txBuffer,size);	//write data to send
	SpiStrobe(CC1101_STX);					//start send
	while (!digitalRead(GDO0));				// Wait for GDO0 to be set -> sync transmitted
	while (digitalRead(GDO0));				// Wait for GDO0 to be cleared -> end of packet
	SpiStrobe(CC1101_SFTX);				//flush TXfifo
	//Serial.println("SendData-CHECK");
*FUNCTION NAME:SetReceive
*FUNCTION     :set CC1101 to receive state
*INPUT        :none
*OUTPUT       :none
void ELECHOUSE_CC1101::SetReceive(void)
	SpiStrobe(CC1101_SRX);
*FUNCTION NAME:CheckReceiveFlag
*FUNCTION     :check receive data or not
*INPUT        :none
*OUTPUT       :flag: 0 no data; 1 receive data
byte ELECHOUSE_CC1101::CheckReceiveFlag(void)
	if(digitalRead(GDO0))					//receive data
		return 1;
	else							// no data
		return 0;
*FUNCTION NAME:ReceiveData
*FUNCTION     :read data received from RXfifo
*INPUT        :rxBuffer: buffer to store data
*OUTPUT       :size of data received
byte ELECHOUSE_CC1101::ReceiveData(byte *rxBuffer)
	byte size;
	byte status[2];
	if(SpiReadStatus(CC1101_RXBYTES) & BYTES_IN_RXFIFO)
		size=SpiReadReg(CC1101_RXFIFO);
		SpiReadBurstReg(CC1101_RXFIFO,rxBuffer,size);
		SpiReadBurstReg(CC1101_RXFIFO,status,2);
		SpiStrobe(CC1101_SFRX);
		return size;
		return 0;
ELECHOUSE_CC1101 ELECHOUSE_cc1101;
However, I have not managed to get it to work on the Teensy 4.0.
While debugging the code I noticed that the code hangs on the first call of SPI.transfer() on the Reset() function from ELECHOUSE library
I already read the following threads to try to fix my problem:
[https://forum.pjrc.com/threads/57507-SPI-on-Teensy-4]
[https://forum.pjrc.com/threads/61932-Different-SPI-Behavior-on-Teensy-4-0-and-4-1]
[https://forum.pjrc.com/threads/59906-SPI-MOSI-pulled-low-too-late-on-Teensy-4-0]
But I am still unsuccessful.
At the moment I do not have access to an oscilloscope due to the COVID-19 situation so I cannot do an analysis of the SPI signals.
It is worth mentioning that the library that I modified works on an Arduino nano and Arduino UNO, taking into account that the connections must be at 3.3v
It is also important to say that I am using the updated SPI library: [https://github.com/PaulStoffregen/SPI]
The connections on the Teensy 4.0 were direct due to the maximum voltage being 3.3v so I omitted the resistors
Please, help understand what I'm doing wrong :( :( :confused: :confused:
  • SPI.h
  • SPI.cpp
Add SPI.begin() in your setup() function.
It is on the ELECHOUSE_cc1101.Init(); when it call ELECHOUSE_CC1101::SpiInit() on the library.
But it still doesn't work when i add it in the Arduino code.
[COLOR="#FF0000"]#include <SPI.h> // For SPI functions[/COLOR]
int tiempo = 20;
byte i;
//int x=0;
int x, y, z;
[COLOR="#FF0000"]  SPI.begin();[/COLOR]
  delay(1);
  x = -90;
  Serial.println(x);
  if (x < 0) {
I don't know what I'm doing wrong, I really sorry for this noob question.
Normally, SPI does not "hang" -- even if you have nothing connected to SPI pins. I would get rid of all the while(digitalRead(MISO_PIN));, 1) because the while is probably causing the hang and 2) you're using digital IO with the SPI pins while they are in SPI mode, a very non-standard approach.
and get rid of
those pins need to remain in "SPI mode" after the SPI.begin(). Only the SS_PIN should be in OUTPUT mode.
To avoid a problem with the library, first try without the library and perform a basic SPI transfer. Like this:
const int SS_PIN = 10;          // assuming MOSI 11, MISO 12, SCK 13
  SPI.begin();
  pinMode(8, OUTPUT);           // debugger pin
  digitalWrite(8, LOW);         // set debugger output low
  digitalWrite(SS_PIN, HIGH);   // set SS pin inactive
  digitalWrite(SS_PIN, LOW);    // set SS low
  delay(1);                     // datasheet states to wait for minimum 150us/20ns depending on chip mode
  //digitalWrite(8,1);          // Just for debugging purposes
  SPI.transfer(0x30);           // CC1101_SRES = 0x30
  digitalWrite(8, 1);           // Just for debugging purposes
  digitalWrite(SS_PIN, HIGH);   // set SS high
Paul
and get rid of
In fact, putting SPI pins (SCK,MOSI,MISO) into OUTPUT disables SPI transfer.
Well, the ELECHOUSE_CC1101 library is just doing that...
	SPI.begin(); //
	//SpiMode(0);
Paul
	SPI.begin(); //
	//SpiMode(0);
Paul
yes, the ELECHOUSE lib is built on the AVR SPI. The Teensy/ARM SPI requires different logic
  SPI.begin();
Paul
I'm sorry I was slow to respond, I was testing what you mentioned in your comments.
That code really works, I even removed the "delay(1);" line and it still works.
I noticed that you removed the declarations from the pins after SPI.begin ():
SPI.begin (); //
pinMode (SCK_PIN, OUTPUT); // ERASED
pinMode (MOSI_PIN, OUTPUT); // ERASED
pinMode (MISO_PIN, INPUT); // ERASED
pinMode (SS_PIN, OUTPUT); // still on code
As MINITOU said, those lines in the SpiInit(void) method were the problem, a problem that only occurs in Teensy 4.0 because I don't have that problem when using an Arduino Nano or an Arduino UNO.
[COLOR="#FF0000"]const int SCK_PIN = 13;  // Adding just for the test
const int MOSI_PIN = 11; // Adding just for the test
const int MISO_PIN = 12; // Adding just for the test
[/COLOR]
  SPI.begin();
/*Spanish comment sorry, I'm from Mexico*/
/* Al descomentarse el SPI en la Teensy NO funciona pero en Arduino sí */
[COLOR="#FF0000"]// These lines works for Arduino UNO/NANO, but doesn't work for Teensy 4.0, that's why are commented.
//  pinMode(SCK_PIN, OUTPUT);
//  pinMode(MOSI_PIN, OUTPUT);
//  pinMode(MISO_PIN, INPUT); [/COLOR]
  Serial.println("Sí pasó, wey :D");
Thank you very much for the support.
You're welcome.
With respect to removing delay(1);, I'm not sure whether that is a good idea for the first time you are talking the CC1101 after power up.
If I read chapter 19 of the CC1101 spec correctly, the chip is in power-down mode after power up, so you have to meet the 150us spec in Table 22: SPI Interface Timing Requirements.
Here is a screendump of the SPI transfer without the delay(1); inserted: [measured on a Teensy 4.0 @ 600MHz]
After SS going low, it takes ~240nsec for the SCK to become active. For normal operation, this meets the 20nsec spec but not for power-down mode.
So my suggestion would be to keep in the delay(1); for the first SPI transaction [SRES command strobe]; subsequent SPI transfers don't need a delay.
If you are really picky on timing, you could replace delay(1); by delayMicroseconds(150);.
Paul
