Results 1 to 4 of 4
Thread: Something different about Teensy SPI?
    Aug 2020
    17
    This simple sketch works on Arduino UNO but not on Teensy 4.0. On the Teensyit tries to display Hello World but it shows up in the wring place with some of the letters corrupted. I suspect the Teensy's 600 Mhz clock vs UNO's 16 Mhz clock has something to do with it. But what can I do to make it work?
    This is the display and it is in SPI mode. https://smile.amazon.com/gp/product/B00TIYUWNY/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    #include "Adafruit_HX8357.h"
    #include <Adafruit_GFX.h>    // Core graphics library
    #include "TouchScreen.h"
    // These are the four touchscreen analog pins
    #define YP A2  // must be an analog pin, use "An" notation!
    #define XM A3  // must be an analog pin, use "An" notation!
    #define YM 7   // can be a digital pin
    #define XP 8   // can be a digital pin
    TouchScreen tscr = TouchScreen(XP, YP, XM, YM, 500);
    #define MINPRESSURE 300
    #define MAXPRESSURE 1000
    // The display uses hardware SPI, plus #9 & #10
    #define TFT_RST -1  // dont use a reset pin, tie to arduino RST if you like
    #define TFT_DC 9
    #define TFT_CS 10
    // This is calibration data for the raw touch data to the screen coordinates
    #define TS_MINX 110
    #define TS_MINY 80
    #define TS_MAXX 900
    #define TS_MAXY 940
    Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
    // Colors
    #define BACKGROUND 0xB5B6
    #define HIGHLIGHT 0x0500
    #define TEXTCLR 0x0000
    #define BORDER 0x0000
    #define BUTTON 0xAD75
    #define RED 0xA800
    #define GREEN 0x0360
    #define WHITE 0xFFFF
      tft.begin();
      tft.fillScreen(WHITE);
      tft.setTextSize(3);
      tft.setCursor(130,150);
      tft.setTextColor(TEXTCLR);
      tft.setRotation(1);
      tft.print("Hello World");
    Jul 2020
    406
    The Adafruit library limits the SPI clock to 24MHz I think. Its defined in Adafruit_HX8357.cpp, SPI_DEFAULT_FREQ - you could
    try dialling it down to 8MHz or so in case the timing is borderline. Make sure the SPI bus wiring and its ground are nice and tightly
    laid out, these high speed signals don't take kindly to spaghetti layout.
    Aug 2020
    17
    I moved the USB cable from the USB hub and plugged it directly into the PC and all is well. Go figure.
    Jul 2020
    406
    Quote Originally Posted by PickyBiker View Post
    Poor hub supply, plus a lacklustre cable, can drop 5V down significantly... Many USB cables have flimsy little wires inside, so you
    really want a 5.25V USB supply to allow for this.
