Results 1 to 3 of 3
Thread: RTC problem with Teensy 4.0
    Aug 2020
    17
    The sketch below is the standard Arduino RCTLib example for DS1307. When run, it simply sends a serial message that says, "Couldn't find RTC", Is there something different that needs to be used on the Teensy 4.0 to use the RTC?
    // Date and time functions using a DS1307 RTC connected via I2C and Wire lib
    #include "RTClib.h"
    RTC_DS1307 rtc;
    char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
    void setup () {
      Serial.begin(57600);
    #ifndef ESP8266
      while (!Serial); // wait for serial port to connect. Needed for native USB
      if (! rtc.begin()) {
        Serial.println("Couldn't find RTC");
        Serial.flush();
        abort();
      if (! rtc.isrunning()) {
        Serial.println("RTC is NOT running, let's set the time!");
        // When time needs to be set on a new device, or after a power loss, the
        // following line sets the RTC to the date & time this sketch was compiled
        rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
        // This line sets the RTC with an explicit date & time, for example to set
        // January 21, 2014 at 3am you would call:
        // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
      // When time needs to be re-set on a previously configured device, the
      // rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    void loop () {
        DateTime now = rtc.now();
        Serial.print(now.year(), DEC);
        Serial.print('/');
        Serial.print(now.month(), DEC);
        Serial.print('/');
        Serial.print(now.day(), DEC);
        Serial.print(" (");
        Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
        Serial.print(") ");
        Serial.print(now.hour(), DEC);
        Serial.print(':');
        Serial.print(now.minute(), DEC);
        Serial.print(':');
        Serial.print(now.second(), DEC);
        Serial.print(" since midnight 1/1/1970 = ");
        Serial.print(now.unixtime());
        Serial.print("s = ");
        Serial.print(now.unixtime() / 86400L);
        Serial.println("d");
        // calculate a date which is 7 days, 12 hours, 30 minutes, and 6 seconds into the future
        DateTime future (now + TimeSpan(7,12,30,6));
        Serial.print(" now + 7d + 12h + 30m + 6s: ");
        Serial.print(future.year(), DEC);
        Serial.print('/');
        Serial.print(future.month(), DEC);
        Serial.print('/');
        Serial.print(future.day(), DEC);
        Serial.print(' ');
        Serial.print(future.hour(), DEC);
        Serial.print(':');
        Serial.print(future.minute(), DEC);
        Serial.print(':');
        Serial.print(future.second(), DEC);
        delay(3000);
    Oct 2019
    Calgary
    77
    Try this. It's a stripped down version of the TimeTeensy3 example (yes it works with Teensy4, don't let the name throw you):
     * TimeTeensy3.ino
     * example code illustrating Time library with Real Time Clock.
    #include <TimeLib.h>
    void setup()  {
      // set the Time library to use Teensy 3.0's RTC to keep time
      while (!Serial);  // Wait for Arduino Serial Monitor to open
      if (timeStatus()!= timeSet) {
        Serial.println("Unable to sync with the RTC");
        Serial.println("RTC has set the system time");
      digitalClockDisplay();
    void digitalClockDisplay() {
      // digital clock display of the time
      Serial.print(hour());
      printDigits(minute());
      printDigits(second());
      Serial.print(" ");
      Serial.print(day());
      Serial.print(" ");
      Serial.print(month());
      Serial.print(" ");
      Serial.print(year());
    time_t getTeensy3Time()
      return Teensy3Clock.get();
    void printDigits(int digits){
      // utility function for digital clock display: prints preceding colon and leading 0
      Serial.print(":");
      if(digits < 10)
        Serial.print('0');
      Serial.print(digits);
    Aug 2020
    17
    That seems to work. Thanks!
