Results 1 to 5 of 5
Thread: Can you write unit tests for Arduino stuff?
    Jul 2020
    103
    For some years I have been using test-driven development (TDD) to good effect in my career, which is writing software that runs on "full" computers. The learning curve is steep, but it makes code so much easier to develop and maintain that I can't see a reason to go back to the old way.
    Well, maybe one reason, where Arduino-based stuff is concerned: I don't know if it can be done. There is a lot of stuff like delayMicroseconds() that isn't in a standard libc, so I don't know how it would compile for my dev machine.
    Obviously, I can't test things like interrupts and GPIO on an x86-64 target, but the majority of code is at a higher level of abstraction and could be unit-tested, if only it could be made to compile.
    Anyone have any luck with this?
    Jul 2020
    322
    Quote Originally Posted by Pilot View Post
    You need a test-harness version of the Arduino libraries to compile against, one that can be programmed to behave in certain
    ways that you expect the hardware to do, then you can test the software against that, for various scripts. The test harness
    would use virtual time so delays are magiced away.
    Its a lot of work of course, both to write such a library and to construct harnesses for each hardware setup. Its often easier
    to just use the real hardware and automated test equipment (or people) talking to that hardware.
    Its a good reason to separate I/O and hardware interfacing into small modules so the the rest of the code can be tested
    in isolation.
    22,470
    I recently started some work towards automated regression testing, but it's barely past the planning phase, and I'm not ready to write a lengthy post about it.
    But here's a photo....
    Jul 2020
    103
    Some good stuff here.
    I think it would be somewhat "arduous" to make Arduino stuff compile on regular old g++.
    I guess you could split the difference: write as much code in a platform-agnostic way as possible, and put Arduino-specific stuff like delayMicroseconds() into utility classes that look something like this:
    void Time::delayMicroseconds(int uS) {
        #IFDEF ARDUINO
        delayMicroseconds(uS);
        #ELSE
        usleep(uS);
        #ENDIF
