Results 1 to 10 of 10
Thread: Teensyduino: Missing Audio.h
    Dec 2018
    18
    I am running Arduino 1.8.7 with teensyduino 1.5.0, however I do not seem to have the Audio examples, or the ability to include the Audio.h file in my sketches ("Audio.h: No such file or directory").
    I read here https://www.pjrc.com/teensy/td_libs_Audio.html that Audio is included in the installer. I tried installing the Catalina standalone version of teensyduino/arduino (I'm running OS 10.13.6) and had the same issue.
    Am I missing something basic?
    Thank you!
    Dec 2018
    18
    I've since upgraded to Arduino 1.8.13 and Teensyduino 1.53 to make sure that my versions are compatible. I was still not able to locate the Audio library. I have since tried installing the library manually from github by loading the zip file into the arduino IDE.
    The examples show up now, however when trying to include the Audio.h file, I receive this error:
    In file included from /Users/jj2/Documents/Arduino/2020_8_9_PJRCFeatherTest/2020_8_9_PJRCFeatherTest.ino:9:0:
    /Users/jj2/Documents/Arduino/libraries/Audio-master/Audio.h:31:2: error: #error "Teensyduino version 1.20 or later is required to compile the Audio library."
    /Users/jj2/Documents/Arduino/libraries/Audio-master/Audio.h:37:10: fatal error: DMAChannel.h: No such file or directory
     #include "DMAChannel.h"
    compilation terminated.
    Using library Audio-master at version 1.3 in folder: /Users/jj2/Documents/Arduino/libraries/Audio-master
    exit status 1
    Error compiling for board Adafruit Feather M4 Express (SAMD51).
    The code I'm running is example code for getting started on an Adafruit Feather M4 using the tonesweep object connected to a DACs object.
      Audio Library on Trellis M4
      Demo of the audio sweep function.
      The user specifies the amplitude,
      start and end frequencies (which can sweep up or down)
      and the length of time of the sweep.
    // Paste your Audio System Design Tool code below this line:
    AudioSynthToneSweep      tonesweep1;     //xy=204,158
    AudioOutputAnalogStereo  Audio_Output;          //xy=390,148
    AudioConnection          patchCord1(tonesweep1, 0, Audio_Output, 0);
    AudioConnection          patchCord2(tonesweep1, 0, Audio_Output, 1);
     GUItool: end automatically generated code
    float t_ampx = 0.05;  // Amplitude
    int t_lox = 10;  // Low frequency
    int t_hix = 22000;  // High frequency
    float t_timex = 10; // Length of time of the sweep in seconds
    void setup(void)
      //while (!Serial) ;
      delay(3000);
      AudioMemory(6);
      Serial.println("setup done");
      if(!tonesweep1.play(t_ampx,t_lox,t_hix,t_timex)) {
        Serial.println("AudioSynthToneSweep - begin failed");
        while(1);
      // wait for the sweep to end
      while(tonesweep1.isPlaying());
      // and now reverse the sweep
      if(!tonesweep1.play(t_ampx,t_hix,t_lox,t_timex)) {
        while(1);
      Serial.println("Done");
    void loop(void)
    Aug 2018
    Brisbane, Australia
    24
    On my machine with the same versions as you, it is installed here
    /usr/share/arduino/hardware/teensy/avr/libraries/Audio/Audio.h
    12,194
    On Windows unzip install I find it here for same versions: "T:\arduino-1.8.13\hardware\teensy\avr\libraries\Audio\Audio.h "
    But error is not missing that file - but finding it and saying this file included there is missing ::
    But first - if TeensyDuino is 1.53 - this error should not be showing?
    And :: libraries/Audio-master
    shows this is a private local copy of the Audio library from github - not the TeensyDuino installed version?
    That should not be needed with a valid and complete TeensyDuino install.
    Dec 2018
    18
    Thanks for your replies. I am also confused as to why I am seeing the error about TeensyDuino version 1.2. When I go to Arduino >> About I am able to see that the correct version (1.53) is being referenced:
Name:	Screen Shot 2020-08-10 at 11.25.44 AM.png
    I also looked in the Audio.h file that I am referencing, and see that on line 7 it calls to include the DMAChannel.h file. Where should this be located?
    I am attempting to follow this guide: https://learn.adafruit.com/synthesiz...s?embeds=allow
    Thanks in advance for any further help.
    22,480
    Check the Tools > Boards menu. Any chance you have a non-Teensy board selected?
    Arduino changes where it looks for files depending on what platform/board you choose in that menu.
    Dec 2018
    18
    Yes, I am using an adafruit Feather M4 express, and following this guide: https://learn.adafruit.com/synthesiz...s?embeds=allow
    The above guide is for the Neotrellis button pad, however I was told that it should work with the Feather M4 as well. If I should be asking for help over at Adafruit instead of here, please let me know.
    Thanks again.
    Dec 2018
    18
    I see now that there is a page prior to where I linked, that requires installation of a forked version of the library. Sorry for the confusion, and thanks for your replies.
    12,194
    Yes, that would be an AdaForum quesion for :: 2020_8_9_PJRCFeatherTest/2020_8_9_PJRCFeatherTest.ino
    They make a feather shield for Teensy - should have asked about that rather than let it slide. The M4 isn't related to PJRC.
    Go into the Library Manager and check for Library updates. I let a board sit 1 month after updates and there were 14 pulled in libraries it updated the other day when checked. It also brings in related needed libraries.
    Be aware of local sketchbook\libraries - they can get in the way. Careful reading of the 'verbose' console output has lots of detail.
    Dec 2018
    18
    thank you for the suggestions. I think my confusion stemmed from not knowing that the Arduino Examples menu is populated based on the board that's selected.
