Results 1 to 6 of 6
Thread: Curved text on RA8875 display
    May 2017
    Netherlands
    121
    Hi all,
    For my newest power meter I like to print curved text on the display, so I like print the text in a curved position on my RA8875 display. I can change a liberation_mono.ttf say the character F in every angle adjusted with fontforge, to get the full word FORWARD curved is a lot of work.
    Is there a easier way to do this?
    Every suggestion is very welcome!
    Best regards,
    Johan
    May 2017
    Netherlands
    121
    This is what I mean for curved text.Click image for larger version.
    7,402
    Looks like fun.
    Not sure How I would try to do it. If these were the only thing to display like this, I might be tempted to have a bitmap with it that I just put up on display. But that is probably cheating.
    When you are wanting to curve the text, are you also trying to curve each character? That is with the F does the angle of the logically vertical line at same angle as the farthest away dots of the horizontal lines?
    May 2017
    Netherlands
    121
    Hi Jurt,
    Thanks for the repley!
    I turn every char in the Liberation_mono.ttf and convert it to .c but this is very time consuming.
    I think there must be a easier way perhaps on pixel level to turn every character on the right angle, to get a nice curved word ...
    Perhaps someone has a smart idea.... I not see this before on any display so investigation is more than welcome.
    Best,
    Johan
    Jul 2020
    303
    There's always the bitmap rotate trick with 3 shear transforms, but its very pixelated. https://www.ocf.berkeley.edu/~fricke..._shearing.html
    May 2017
    Netherlands
    121
    To complex for me
    Thanks anyway.
    Johan
