Results 1 to 2 of 2
Thread: Spi devices with different clock speeds
    May 2020
    17
    Hi, im wondering how to handle spi when chips have diffrent max clock speeds.
    should i change clock speed between communicating with different chips?
    Or should i use two buses with diffrent clocks?
    Or, just use one bus and set the clock acording to max speed of the slowest chip?
    in my case i have a adc(17mhz), dac(50mhz), io expander(10mhz)
    22,996
    Use SPI.beginTransaction() to set up the speed and other settings, and SPI.endTransaction() when you're done.
    This is standard on all Arduino boards (though it was originally developed on Teensy). Here's Arduino's documentation:
    https://www.arduino.cc/en/Reference/SPIbeginTransaction
