Results 1 to 6 of 6
Thread: How to use the teensy 4.1 microSD card - A tutorial for beginners.
    Hi everyone! I cant seem to find any tutorials on how to use the teensy 4.1 microSD so Im offering to make one for youtube if someone can help with the code.
    The project will have the following:
    Teensy 4.1
    microsd card
    2 x buttons (one wired to pin 7 and one wired to pin 8)
    2 x resistors
    1 x10k potentiometer.
    The goal will be to read the value of the potentiometer and print it when the value is changed
    Pressing the button wired to pin 7 will save the current value of the potentiometer to the SD card
    Pressing the button wired to pin 8 will print the value saved to the sd card.
    here is a schematic of what it'll look like (very simple)
    and here's what the wiring will end up lookin like
    Im horrible at coding but heres a starting point....
    /* how to save to SSD Tutorial
      Serial.begin(38400);
      pinMode(7, INPUT);
      pinMode(8, INPUT);
    int val = analogRead(A0);
     int val = analogRead(A0); // reads the pot to see the current value
    Serial.print("The value is: "); //prints the value of the pot
    Serial.println(val);
      if (digitalRead(7) == HIGH) {              //if the button wired to pin 7 is pressed - save the value of the pot to the sd card
       Serial.println("value saved!!!!!!!!");
    if (digitalRead(8) == HIGH) {  // if the button wired to pin 8 is pressed - print the value of the saved value
       Serial.print("the saved value is:");
      delay(250);
    12,231
    Hopefully this is the direction you are looking for?
    Look for : ...\hardware\teensy\avr\libraries\SD\examples\Data logger\Datalogger.ino
    Those Examples are under SD and use the TeensyDuino included SD library.
    In those examples or when using that library specify ::
    // Teensy 3.5 & 3.6 & 4.1 on-board: BUILTIN_SDCARD
    const int chipSelect = BUILTIN_SDCARD;
    There are other examples for digital and analog if those are needed.
    I dont understand where you are suggesting I look.
    Is datalogger.ino a file that should be on my computer somewhere?
    It turns out i installed my teensy drivers but did not install the teensyduino libraries.
    I installed the libraries to my arduino folder using the teensyduino installer and found datalogger.ino !
    Ill play around with it tonight
    12,231
    Cool, have fun - good luck
    gettin' closer!
    here is my code so far. It works but I feel like I could simplify things a bit more
      SD card datalogger
     This example shows how to log data from two digital sensors and one analog sensor
     to an SD card using the SD library.
    In this example you can fiddle with a potentiometer,
    press a button to save the value of the pot to the teensy 4.1 microSD
    and press a different button to display what value was saved.
     The circuit:
     * analog sensors on analog ins 0, 1, and 2
     * SD card attached to SPI bus as follows:
     ** MOSI - pin 11, pin 7 on Teensy with audio board
     ** MISO - pin 12
     ** CLK - pin 13, pin 14 on Teensy with audio board
     ** CS - pin 4,  pin 10 on Teensy with audio board
     created  24 Nov 2010
     modified 9 Apr 2012
     by Tom Igoe
    then modified again (horrible) by Andrew C.
    // On the Ethernet Shield, CS is pin 4. Note that even if it's not
    // used as the CS pin, the hardware CS pin (10 on most Arduino boards,
    // 53 on the Mega) must be left as an output or the SD library
    // functions will not work.
    // change this to match your SD shield or module;
    // Arduino Ethernet shield: pin 4
    // Adafruit SD shields and modules: pin 10
    // Sparkfun SD shield: pin 8
    // Teensy audio board: pin 10
    // Wiz820+SD board: pin 4
    // Teensy 2.0: pin 0
    // Teensy++ 2.0: pin 20
    //create an integer named "pot" This integer will be used for the value of the potentiometer.
    int pot;
    //this part sets things up!
      //UNCOMMENT THESE TWO LINES FOR TEENSY AUDIO BOARD:
      //SPI.setMOSI(7);  // Audio shield has MOSI on pin 7
      //SPI.setSCK(14);  // Audio shield has SCK on pin 14
       while (!Serial) {
        ; // wait for serial port to connect.
      // see if the card is present and can be initialized:
      if (!SD.begin(chipSelect)) {
        Serial.println("Card failed, or not present");
        // don't do anything more:
        return;
      Serial.println("card initialized.");
      // make a string for assembling the data to log:
      String dataString = "";
          //if button wired to digital pin 7 is pressed, print "button 7 pressed - data saved!" to serial
            Serial.println("button 7 pressed - data saved!");
          //read the potentiometer's value. then use this value as the new value of dataString
              int pot = analogRead(A0);
              dataString = String(pot);
          // open the file named datalog.txt on the sd card
              File dataFile = SD.open("datalog.txt", FILE_WRITE);
              // if the file is available, write the contents of datastring to it
              if (dataFile) {
              dataFile.println(dataString);
              dataFile.close();
              // if the file isn't open, pop up an error:
              else {
              Serial.println("error opening datalog.txt");
    //if button wired to digital pin 8 is pressed, print "button 8 pressed - load" to serial
            Serial.println("button 8 pressed - load");
          //open up datalog2.txt and then print all of its contents
            File dataFile = SD.open("datalog.txt");
            if(dataFile) {
              Serial.println("datalog:");
              while (dataFile.available()) {
                  Serial.write(dataFile.read());
          // close the file:
             dataFile.close();
    //Delete the file so it can be created again at the begining of the loop
    SD.remove("datalog.txt");
        // if the file didn't open, print an error:
      delay(150);
