Results 1 to 5 of 5
Thread: Dimensions and pin locations for Teensy 4.1
    Aug 2020
    UK
    4
    We need to layout a carrier for 4.1's, is there a dimensioned drawing of where all the pins are we can use a reference? need to get all the thru-hole pins in the right place...
    David
    Senior Member PaulS's Avatar
    Apr 2015
    Netherlands
    294
    Hi David, did you see this page?
    And saw this thread? https://forum.pjrc.com/threads/60348...nsy-4-0-(test)
    Cheers,
    Paul
    Aug 2020
    UK
    4
    Thansk, no, ideally a properly dimesion darwing would boog as we do not use eagle!
    Quote Originally Posted by PaulS View Post
    Cheers,
    Paul
    22,662
    I've updated the dimensions page. I know this thread is a bit old by now, but hopefully it helps?
    https://www.pjrc.com/teensy/dimensions.html
    Aug 2020
    UK
    4
    Thanks Paul, we will check against the design, not made pcbs yet!
    David
