Hi
I have a question how to talk to the AD7124-8 based on the Evaluation board CN0391.
how can I write to the registers? or get info back from the registers?
I had many similar questions, but going back to the basics is the best at the moment. This is because my project is larger, and i am not getting the right values from the CN0391 evaluation board, even if the Thermocouples are connected or not, which show no errors or fail or what so ever.
for setting the thermocouples I require to set AD7124-8 specific Registers, Options, Channels, Currents and filters, even Bias and offsets. if someone could please explain me how to decifer the Registers I would be very glad. because the standard libraries aint communicating that well, getting rubbish values like 2.5V or 0.000, or FAIL or other none understandable gibberish.
the CN0391.ino is no option to use because there is so much going and it isnt allowing my to write any data to the tft screen.
so resorting to the AD7124 is necessary and implement the code around it.
I grapped from the AD7124 the full test ino to check if I can read and write any value. but I simply dont know how to do this at best.
full test code:
here is the serial monitor output values from the full test code.
AD7124 Full Test
> Setting up 4 channels with 4 setup
> Config0(0x19) = 0x9F0
> Channel0(0x9) = 0x31
> Config1(0x1A) = 0x9F0
> Channel1(0xA) = 0x1071
> Config2(0x1B) = 0x9F0
> Channel2(0xB) = 0x20B1
> Config3(0x1C) = 0x9F0
> Channel3(0xC) = 0x30F1
> Setting up ADC
> (0x1) = 0x1188
> Calibration
> Offset0(0x29) = 0x800000
> Gain0(0x31) = 0x554E8A
> Offset1(0x2A) = 0x800000
> Gain1(0x32) = 0x554E8A
> Offset2(0x2B) = 0x800000
> Gain2(0x33) = 0x554E8A
> Offset3(0x2C) = 0x800000
> Gain3(0x34) = 0x554E8A
> V0 V1 V2 V3
> -0.000 -0.000 -0.000 -0.000
> 2.500 -0.000 -0.000 -0.000
many thanks!
happy weekend.
full test code:
AD7124 Full Test
Prints out the voltages measured at pins AIN1/AIN, AIN3/AIN2, AIN5/AIN4 and
AIN7/AIN6. Input voltages must be in the range between 0 and 2.5V.
This is a complete test program that checks for errors and displays the
contents of the AD7124 circuit registers.
For a more accessible example see voltmeter.ino.
For more on AD7124, see
http://www.analog.com/media/en/technical-documentation/data-sheets/AD7124-4.pdf
The circuit:
- AD7124 connected on the MOSI, MISO, SCK and /SS pins (pin 10)
- LED active in low state connected to pin 9.
created 2018
by epsilonrt https://github.com/epsilonrt
https://github.com/epsilonrt/ad7124/tree/master/examples
#include <stdlib.h>
#include <ad7124.h>
using namespace Ad7124;
// In order not to prefix the constants with Ad7124 :: !
//using namespace Ad7124;
/* constants ================================================================ */
const int ledPin = 9;
const int ssPin = 10;
/* macros =================================================================== */
// Evaluate assertion macro
// If the argument expression of this macro with functional form compares equal
// to zero (i.e., the expression is false), a message is written to the serial
// device and abort is called, terminating the program execution.
#define assert(e) ((e) ? (void)0 : __assert(__func__, __LINE__, #e))
/* public variables ========================================================= */
Ad7124Chip adc;
/* internal public functions ================================================ */
// Prints AD7124 register value
void printreg (int reg) {
char name[16];
if (Ad7124Register::copyRegisterName (reg, name) > 0) {
long value = adc.getRegister (reg);
if (value >= 0) {
Serial.print (name);
Serial.print ("(0x");
Serial.print (reg, HEX);
Serial.print (") = 0x");
Serial.println (value, HEX);
// Print assertion function
// a message is written to the serial device and abort is called, terminating
// the program execution.
void __assert (const char *__func, int __lineno, const char *__sexp) {
Serial.print ("Error in ");
Serial.print (__func);
Serial.print ("(): line ");
Serial.print (__lineno);
Serial.print (", assertion failed: ");
Serial.print (__sexp);
Serial.println (", abort !");
delay (1000); // leave time for the message to appear before aborting
abort();
int ret;
pinMode (ledPin, OUTPUT);
digitalWrite (ledPin, 1); // clear the LED
//Initialize serial and wait for port to open:
Serial.begin (38400);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// prints title with ending line break
Serial.println (F ("\nAD7124 Full Test"));
// Initializes the AD7124 device, the pin /CS is pin 10 (/SS)
ret = adc.begin (ssPin);
assert (ret == 0);
Serial.println (F ("\nSetting up 4 channels with 4setup"));
for (uint8_t i = 0; i < 4; i++) {
ret = adc.setConfig (i, RefInternal, Pga1, true);
assert (ret == 0);
printreg (Config_0 + i);
ret = adc.setChannel (i, i, (i * 2 + 1), AVSSInput);
assert (ret == 0);
printreg (Channel_0 + i);
Serial.println (F ("\nSetting up ADC"));
ret = adc.setAdcControl (StandbyMode, FullPower, true);
assert (ret == 0);
printreg (ADC_Control);
Serial.println (F ("\nCalibration"));
printreg (Offset_0 + i);
printreg (Gain_0 + i);
Serial.println (F ("\nV0\tV1\tV2\tV3"));
int ret;
long value;
double voltage;
digitalWrite (ledPin, 0);
value = adc.read (i);
if (value >= 0) {
voltage = Ad7124Chip::toVoltage (value, 1, 2.5, true);
Serial.print (voltage, 3);
Serial.write ('\t');
else {
Serial.print ("FAIL\t");
Serial.write ('\n');
AD7124 Full Test
> Setting up ADC
> (0x1) = 0x1188
> Calibration
> V0 V1 V2 V3
many thanks!
happy weekend.
