Results 1 to 3 of 3
Thread: Add missing standard library to PlatformIO core for teensy31
    May 2018
    2
    I ran across the issue solved in this Stack Overflow post. I have a library which has:
    #include <functional>
    and uses functionality from it. When compiling against teensy31 using PlatformIO, I get an error about:
    undefined reference to_write
    My problem was solved by adding:
    build_flags = -llibc -lc
    Could PJRC staff add these flags to the teensy31 PlatformIO board definition? I believe that even with that flag, the linker won't actually include the code unless they're actually used. I spent a couple of hours debugging this before I found the answer, so it'd be nice to fix this if possible.
    P.S. is the PlatformIO board definition available somewhere? I'd try to submit a pull request if it is.
    Senior Member blackketter's Avatar
    May 2015
    San Francisco
    299
    Quote Originally Posted by ademuri View Post
    I think this might be what you are looking for: https://github.com/platformio/platfo...develop/boards
    May 2018
    2
    Yep, that's the one, thanks!
    Created a pull request: https://github.com/platformio/platform-teensy/pull/67
