Hi Everyone!
I am having some problems when trying to send a file from the SD card over the network. This worked fine for a T3.6 and WIZ850io hardware module but not with the T4.1 and Native Ethernet. Any ideas or help is appreciated!
Attached is some sample code I made to replicate the issue. I have a T4.1 with the original Ethernet kit from PJRC. Using Teensyduino 1.53 and Arduino IDE 1.8.9
The sample code tries to pull an image off an SD card and transmit it over the network. Normally i parse the request for an image but for simplicity I made any request to port 80 return the image.
To test use a T4.1 + Ethernet Kit from PJRC, add an image to an SD card called "engine.jpg" or change the name in the sketch to match your image name. Run the program and check the serial monitor for the IP. After entering the IP to a web browser the image should display on screen but i get missing or corrupt data.....
Appreciate any help with this.
//Ethernet Includes
#include <NativeEthernet.h>
//SD Includes
const int chipSelect = BUILTIN_SDCARD; //SD Card T4.1
//TCP Ethernet Variables
#define REQ_BUF_SZ 256 //127
EthernetServer server(80); //HTTP Server Port
EthernetClient client; //HTTP Client
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
int req_index = 0; // index into HTTP_req buffer
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //Store in EEPROM
//Initialize Serial Communication
Serial.begin(921600);
//SD Card Setup
Serial.print("Initializing SD card...");
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
return; // don't do anything more:
Serial.println("card initialized.");
delay(1000); //Random Delay
//Setup Ethernet
Ethernet.begin(mac);
server.begin(); // start to listen for clients
Serial.print("IP = ");
Serial.println(Ethernet.localIP());
//Maintain DHCP
Ethernet.maintain();
//Run Ethernet Loop
eth_loop();
//File Sender
void sendFile(EthernetClient client, char str[]){
File outFile;
int count = 0;
outFile = SD.open(str);
byte clientBuf[512];
int clientCount = 0;
while(outFile.available()){
clientBuf[clientCount] = outFile.read();
clientCount++;
if (clientCount >= 511)
count += clientCount;
client.write(clientBuf, clientCount);
clientCount = 0;
Serial.print("Sent bytes...");
Serial.println(count);
if (clientCount > 0) client.write(clientBuf, clientCount);
outFile.close();
//JPEG Image Header
void jpgHeader(EthernetClient client) {
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: image/jpg");
client.println("Connection: close");
client.println();
//HTTP Ethernet Loop
void eth_loop()
EthernetClient client = server.available(); // try to get client
//client.setConnectionTimeout(1000); // set the timeout duration for client.connect() and client.stop()
if (client) { // got client?
Serial.print("Connected..");
//Serial.print(client.remoteIP());
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
Serial.print(c);
// leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
if (req_index < (REQ_BUF_SZ - 1)) {
HTTP_req[req_index] = c; // save HTTP request character
req_index++;
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
//Send File no matter what request for testing
jpgHeader(client);
sendFile(client, "engine.jpg");
// every line of text received from the client ends with \r\n
if (c == '\n') currentLineIsBlank = true;
else if (c != '\r') currentLineIsBlank = false;
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
Serial.println(" - Disconnected Client");
