Results 1 to 10 of 10
Thread: teensy4 + octows2811 + fastled
    Los Angeles
    125
    Hi all,
    Before I jump too far down this rabbit hole, wanted to ask a question of those with the brains for this. I found how to get the teensy4 and fastLED library to play nicely. And I love the idea idea of being able to define the output pins for the LEDs, but is it possible to combine the two? I have a lot of animations based on the fastLED library (hence my desire to cling on to it). There's a longer story behind this (it's been a journey starting with timing issues and longish strands with the fastLED library using a teensy 3.2), but working on a PCB that's already been manufactured and need to use pins 2,5,6,7, & 8 for LEDs, and free up the rest for other inputs and outputs.
    Just curious before I break something I shouldn't break
    Thanks,
    David
    Los Angeles
    125
    Hi again,
    OK, setting aside fastLED for now and just focusing on teensy4 and the octows2811 library. I need to limit the number of pins the octosw2811 library uses, so using the code provided in the examples folder (i.e. Teensy4_PinList.ino) I specified only the 3 pins I need (2, 5 & 6). Everything looks good on pin 2, but for pin 5 the first 2 LEDs are stuck, and on pin 6 the first 5 pins are stuck. I don't have this issues with other examples in the library (since these share 3 of the 8 octo pins). No stuck LEDs. All signal lines are shifted to 5V with 100Ohm resistors in series. All components on a custom PCB, so no issues with breadboarding/bad wires.
    I'm using the code from the example, but including it here with the mods for the pins I want to use.
    /*  OctoWS2811 Teensy4_PinList.ino - Demonstrate use of any pins
        http://www.pjrc.com/teensy/td_libs_OctoWS2811.html
      With Teensy 4.x, you can use any group of pins.  You are not limited
      to only 8 fixed pins as with Teensy 3.x.  This example shows how to
      use only 4 pins, which are the 4 pins of the Octo28 shield which do
      not conflict with the Audio shield.
      Required Connections
        pin 2:  LED Strip #1
        pin 14: LED strip #2
        pin 6:  LED strip #5
        pin 5:  LED strip #8
    #include <OctoWS2811.h>
    // Any group of digital pins may be used
    const int numPins = 3;
    byte pinList[numPins] = {2, 5, 6};
    const int ledsPerStrip = 186;
    // These buffers need to be large enough for all the pixels.
    // The total number of pixels is "ledsPerStrip * numPins".
    // Each pixel needs 3 bytes, so multiply by 3.  An "int" is
    // 4 bytes, so divide by 4.  The array is created using "int"
    // so the compiler will align it to 32 bit memory.
    DMAMEM int displayMemory[ledsPerStrip * numPins * 3 / 4];
    int drawingMemory[ledsPerStrip * numPins * 3 / 4];
    const int config = WS2811_GRB | WS2811_800kHz;
    OctoWS2811 leds(ledsPerStrip, displayMemory, drawingMemory, config, numPins, pinList);
      leds.begin();
      leds.show();
    #define RED    0xFF0000
    #define GREEN  0x00FF00
    #define BLUE   0x0000FF
    #define YELLOW 0xFFFF00
    #define PINK   0xFF1088
    #define ORANGE 0xE05800
    #define WHITE  0xFFFFFF
    // Less intense...
    #define RED    0x160000
    #define GREEN  0x001600
    #define BLUE   0x000016
    #define YELLOW 0x101400
    #define PINK   0x120009
    #define ORANGE 0x100400
    #define WHITE  0x101010
      int microsec = 2000000 / leds.numPixels();  // change them all in 2 seconds
      // uncomment for voltage controlled speed
      // millisec = analogRead(A9) / 40;
      colorWipe(RED, microsec);
      colorWipe(GREEN, microsec);
      colorWipe(BLUE, microsec);
      colorWipe(YELLOW, microsec);
      colorWipe(PINK, microsec);
      colorWipe(ORANGE, microsec);
      colorWipe(WHITE, microsec);
    void colorWipe(int color, int wait)
      for (int i=0; i < leds.numPixels(); i++) {
        leds.setPixel(i, color);
        leds.show();
        delayMicroseconds(wait);
    Anyone else seen this or have an idea how I can troubleshoot and provide more information?
    Thank you!
    David
    Apr 2017
    833
    For future reference on the thread topic, this is already supported.
    https://github.com/FastLED/FastLED/w...r-with-fastled
    Los Angeles
    125
    Hi vjmuzik,
    Not completely. Can we also specify pins on the T4 (see my OP)? If it is, it's not covered on the page you linked (which I've read many times).
    Thanks,
    David
    Apr 2017
    833
    You would have to edit the class declaration file to add the pin list: https://github.com/FastLED/FastLED/b...1_controller.h
    If you wanted to expose that part to the sketch you could do that as well so it’s more configurable, I can’t test it myself or I would do the edits and make a pull request.
    Los Angeles
    125
    Got it! Let me see what I can break
    Thanks for the pointer!
    Cheers,
    David
    Los Angeles
    125
    And if anyone has any pointers on post #2 in the thread, please let me know!
    Thanks again,
    David
    Mar 2017
    Oakland, CA, USA
    342
    I have a PR that fixes the pixel/bits ordering on a Teensy 4 (tested using a Teensy 4.1): https://github.com/FastLED/FastLED/pull/1309
    The current code doesn't display correctly.
    To alter the pin list, simply add the new list as the last parameter to the `OctoWS2811` constructor, after an additional "number of lanes" parameter:
    new OctoWS2811(nLeds, framebuffer, drawbuffer, config, 8, pinList)
    Note that the default pin list is:
    {2, 14, 7, 8, 6, 20, 21, 5}
    25,208
    Quote Originally Posted by shawn View Post
    I've brought this fix into Teensyduino's copy of FastLED. It'll be in 1.56-beta3 and all future versions.
    Maybe OctoWS2811 should have an example of using FastLED?
    25,208
    I've added a simple example. Hopefully no big surprises... but also hopefully useful to document the proper include / define / include sequence and LEDS.addLeds<>() syntax needed for FastLED to make use of OctoWS2811 for optimized non-blocking output.
    https://github.com/PaulStoffregen/Oc...st_FastLED.ino
