Results 1 to 7 of 7
Thread: how to access the USB client pins D+ and D-
    May 2017
    18
    I'm currently using the Teensy 3.6 and I access to the client USB D+ and D- pins through the pads located on the bottom side below the usb micro connector.
    I want to use the Teensy 4.1 but I can't find a way to access the above mentioned USB pins.
    Paolo
    12,696
    T_4.1 has similar 'device' USB under the USB micro connector. They are smaller 'circle' pads for D+ and D-.
    Quote Originally Posted by paoloboatto View Post
    Paolo
    I had the same problem with a Teensy 4.0. I do not know if the 4.1 is the same, but in my project the 4.0 will be inside a box with a USB panel mounted jack. As someone else mentioned in another thread, what I did was cannibalize a USB cable, plug it into the jack on the 4.0 and solder the other end to the panel mounted jack.
    7,914
    When I was doing a one off box, I used something like: https://smile.amazon.com/CERRXIAN-Fe.../dp/B07G4XYJ5W
    12,696
    On the T_4.0 as @OhioJim discovered the device USB is only on the attached connector, and the similar under pads on the T_4.0 are for USB_HOST. Larger T_4.1 size like the T_3.6 the USBHost pins are in the same place.
    PJRC shipped the T_4.1 with those smaller USB Device pads to make them available with the expectation they would be usable even at the higher 480Mbps speed it provides.
    23,040
    Adafruit sells one too.
    https://www.adafruit.com/product/937
    23,040
    About those pads on the bottom side of Teensy 4.1
