Results 1 to 5 of 5
Thread: USB input to I2S output does not work for Teensy4.1
    Aug 2020
    2
    Not sure why, finally just sent it through queues, but would like this to work.
    Here is the source code for what does not work. I have patched a since wave to the I2S and can see that it works. I have also done notefrequency on the USB input and know that it works, and since I have used queues and that works it is just the AudioConnection.
    AudioInputUSB usb1; //xy=226,133
    AudioOutputI2S i2s1; //xy=399,126
    AudioConnection patchCord1(usb1, 0, i2s1, 0);
    AudioConnection patchCord2(usb1, 1, i2s1, 1);
    AudioMemory(60);
    Feb 2020
    South Africa
    41
    You need AudioControlSGTL5000 sgtl5000_1; object
    I am assuming you are using the audioshield?
    Jun 2018
    134
    File>Examples>Audio>Hardware Testing>PassThroughUSB.
    AudioInputUSB            usb1;           //xy=200,69  (must set Tools > USB Type to Audio)
    AudioOutputI2S           i2s1;           //xy=365,94
    AudioControlSGTL5000     sgtl5000_1;     //xy=302,184
      AudioMemory(12);
      sgtl5000_1.enable();
      sgtl5000_1.volume(0.6);
      // read the PC's volume setting
      float vol = usb1.volume();
      // scale to a nice range (not too loud)
      // and adjust the audio shield output volume
      if (vol > 0) {
        // scale 0 = 1.0 range to:
        //  0.3 = almost silent
        //  0.8 = really loud
        vol = 0.3 + vol * 0.5;
      // use the scaled volume setting.  Delete this for fixed volume.
      sgtl5000_1.volume(vol);
    // Teensyduino 1.35 & earlier had a problem with USB audio on Macintosh
    // computers.  For more info and a workaround:
    // https://forum.pjrc.com/threads/34855-Distorted-audio-when-using-USB-input-on-Teensy-3-1?p=110392&viewfull=1#post110392
    Aug 2020
    2
    Not using any audio shield. This is needed as a generic USB i2s converter in both directions. The I2S input to USB output does not need anything.
    Is there really a dependency in the code so that USB input to I2S out only works with the SGTL5000?
    A waveform to i2s output works. USB input to notefrequency confirms that data comes in through the USB so that only leaves audioconnection().
    23,034
    SGTL5000 is not needed.
    I'm running your code (from msg #1) on a Teensy 4.1 and my PC is playing a MP3 file. Here's what my scope sees on pins 8 and 20.
    If I press the media pause button on my keyboard, the waveforms turn into this:
    Sure looks to me like it's working.
