Yay!
Thank you so much to everyone on this forum for your support along the way!!
Many times was stuck, never gave up.
Learned so much
Youtube: https://www.youtube.com/watch?v=tZ0YGNv9pU0
Learned so much
//Akashic Electronics, July 2020 -EL
//Libraries
#include <PWMServo.h>
// Connections
#define SERVO_PIN 10 // servo, jaw motion
#define PING_PIN 5 // ping for sonar sensor
#define ECHO_PIN 6 // echo for sonar sensor
#define MOSFETPin 9 // mostfet for servo, used as a relay
#define LED_DATA_L 32 //left eye
#define LED_DATA_R 33 //right eye
//Addressable LEDs
#include <WS2812Serial.h>
#define USE_WS2812SERIAL //this is crucial. Paul S.'s DMA Serial library for using WS2812's without interrupts (on Teensy). See documentation.
#include <FastLED.h>
#define LED_TYPE WS2812
#define COLOR_ORDER GRB
#define NUM_LEDS 10
CRGB leds[NUM_LEDS];
#define BRIGHTNESS 20
#define FRAMES_PER_SECOND 20
#define COOLING 10
#define SPARKING 120
bool gReverseDirection = false;
uint8_t gHue = 0;
//Distance sensor
#define SONAR_THRESHOLD 2200 // microseconds --- this triggers at about 1 foot
// Speed of sound in air is about 343 m/s
// Quick calculators:
// const SONAR_THRESHOLD (148 * 6) // ~inches
// const SONAR_THRESHOLD (58 * 15) // ~cm
// Servo
PWMServo jaw;
#define JAW_OPEN 70 //range of servo motion
#define JAW_CLOSED 0
// Length of time for `loop()` to run. 1000/25 Hz (40ms) should be pretty fluid. However this motor is limited to 200ms.
#define SAMPLE_TIME 200 // ms
// Delay playback to compensate for the jaw servo's lag:
#define SERVO_DELAY 50 // ms
// Audio
AudioPlaySdWav playSdWav1; //xy=329,371
AudioMixer4 mixer1; //xy=548,386
AudioEffectDelay delay1; //xy=749,424
AudioOutputAnalog dac1; //xy=951,421
AudioAnalyzePeak peak1; //xy=973,360
AudioConnection patchCord1(playSdWav1, 0, mixer1, 0);
AudioConnection patchCord2(playSdWav1, 1, mixer1, 1);
AudioConnection patchCord3(mixer1, delay1);
AudioConnection patchCord4(delay1, 0, peak1, 0);
AudioConnection patchCord5(delay1, 1, dac1, 0);
#define SDCARD_CS_PIN BUILTIN_SDCARD
#define SDCARD_MOSI_PIN 11 // not actually used
#define SDCARD_SCK_PIN 13
// File array to play when sonar triggers; one will be selected randomly
char * SAMPLE_FILE[] = {"01.wav", "02.wav", "03.wav", "04.wav", "05.wav", "06.wav", "07.wav"};
// playSdWav1 will use the built-in sd card slot, assumed to have a fat32 filesystem.
// `elapsedMillis` is a teensy type that automatically counts up
elapsedMillis sinceTest1;
elapsedMillis sinceTest2;
elapsedMillis sinceTest3;
elapsedMillis sinceTest4;
// Sonar Funtion:
int ping() {
digitalWrite(PING_PIN, LOW);
if (sinceTest1 >= 2) {
sinceTest1 = sinceTest1 - 2;
digitalWrite(PING_PIN, HIGH); }
if (sinceTest2 >= 10) {
sinceTest2 = sinceTest2 - 10;
digitalWrite(PING_PIN, LOW); }
if (pulseIn(ECHO_PIN, HIGH, SONAR_THRESHOLD) != 0) {
return HIGH;
return LOW;
// Mosfet Function:
uint8_t mosfet_state = LOW;
void set_mosfet(uint8_t state) {
if (state != mosfet_state) {
Serial.print("Setting MOSFET to ");
Serial.println(state == LOW ? "LOW" : "HIGH");
mosfet_state = state;
digitalWrite(MOSFETPin, mosfet_state);
Serial.println("initializing audio memory");
randomSeed(analogRead(A0)); //for use with random function
LEDS.addLeds<WS2812SERIAL, LED_DATA_L, COLOR_ORDER>(leds, NUM_LEDS);
LEDS.addLeds<WS2812SERIAL, LED_DATA_R, COLOR_ORDER>(leds, NUM_LEDS);
FastLED.setBrightness(BRIGHTNESS);
// Set up audio memory. You need at least 1 block for each 2.9 ms of delay, plus
// a minimum of 8 blocks for the player.
AudioMemory((int) (ceil(SERVO_DELAY / 2.9) + 8));
Serial.println("initializing pins");
jaw.attach(SERVO_PIN);
pinMode(PING_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
pinMode(MOSFETPin, OUTPUT);
delay1.delay(0, 0);
delay1.delay(1, SERVO_DELAY);
delay1.disable(2);
delay1.disable(3);
delay1.disable(4);
delay1.disable(5);
delay1.disable(6);
delay1.disable(7);
mixer1.gain(0, 1.0);
mixer1.gain(1, 1.0);
mixer1.gain(2, 0);
mixer1.gain(3, 0);
Serial.println("initializing SD access");
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
// stop here, but print a message repetitively
while (1) {
Serial.println(SD.begin(SDCARD_CS_PIN));
// Idling Function:
void loop_state_waiting() {
if (mosfet_state == HIGH) {
Serial.println("playback ended; returning to sleep.");
set_mosfet(LOW);
if (ping() == HIGH) {
Serial.println("sonar ping! Starting sound/animation.");
set_mosfet(HIGH);
if (sinceTest3 >= 5) {
sinceTest3 = sinceTest3 - 5;
byte index = random(0, 6); //call up one of the seven audio files
playSdWav1.play(SAMPLE_FILE[index]);
// ANIMATION FUNCTION:
void loop_state_playing() {
if (peak1.available()) {
float level = peak1.readPeakToPeak();
int new_servo_pos = (int) (level * (JAW_OPEN - JAW_CLOSED) / 1.8 + JAW_CLOSED);
Serial.print("Level: ");
Serial.print(level);
Serial.print("; servo: ");
Serial.println(new_servo_pos);
jaw.write(new_servo_pos);
Fire2012();
//bpm();
red();
//juggle();
//Eventually I can assign different LED codes to different audio tracks using if else statements. TBD.
FastLED.show();
FastLED.delay(1200 / FRAMES_PER_SECOND);
//------------------------------------------------LED_STUFF-------------------------------------------------
//FastLED Opensourced Function:
void Fire2012()
// Array of temperature readings at each simulation cell
static byte heat[NUM_LEDS];
// Step 1. Cool down every cell a little
for( int i = 0; i < NUM_LEDS; i++) {
heat[i] = qsub8( heat[i], random8(0, ((COOLING * 10) / NUM_LEDS) + 2));
// Step 2. Heat from each cell drifts 'up' and diffuses a little
for( int k= NUM_LEDS - 1; k >= 2; k--) {
heat[k] = (heat[k - 1] + heat[k - 2] + heat[k - 2] ) / 3;
// Step 3. Randomly ignite new 'sparks' of heat near the bottom
if( random8() < SPARKING ) {
int y = random8(7);
heat[y] = qadd8( heat[y], random8(160,255) );
// Step 4. Map from heat cells to LED colors
for( int j = 0; j < NUM_LEDS; j++) {
CRGB color = HeatColor( heat[j]);
int pixelnumber;
if( gReverseDirection ) {
pixelnumber = (NUM_LEDS-1) - j;
pixelnumber = j;
leds[pixelnumber] = color;
void juggle() {
// eight colored dots, weaving in and out of sync with each other
fadeToBlackBy( leds, NUM_LEDS, 20);
byte dothue = 0;
for( int i = 0; i < 10; i++) {
leds[beatsin16( i+7, 0, NUM_LEDS-1 )] |= CHSV(dothue, 255, 255);
dothue += 32;
void bpm()
uint8_t gHue = 0;
// colored stripes pulsing at a defined Beats-Per-Minute (BPM)
uint8_t BeatsPerMinute = 12;
CRGBPalette16 palette = PartyColors_p;
uint8_t beat = beatsin8( BeatsPerMinute, 64, 255);
for( int i = 0; i < NUM_LEDS; i++) { //9948
leds[i] = ColorFromPalette(palette, gHue+(i*2), beat-gHue+(i*10));
void red()
leds[i] = CRGB::Maroon; //note the Color Order setting at the beggining ie RGB
//---------------------------------------END_LED_STUFF-------------------------------------------------
// Last but not least:
// resets the counter
//timing = 0;
if (sinceTest4 >= SAMPLE_TIME) {
sinceTest4 = sinceTest4 - SAMPLE_TIME ;
if (!playSdWav1.isPlaying()) {
loop_state_waiting();
fadeToBlackBy( leds, NUM_LEDS, 100);
FastLED.show();
loop_state_playing();
