Results 1 to 6 of 6
Thread: Teensy 4.0 44.1k or 44.117k for sample rate
    Apr 2020
    Guelph Ontario Canada
    66
    I'm using Iowa hills Hilbert filter designer ..in the designer its asking for sampling frequency ..dies the teensy 4.0 run at 44.1 or 44.117 kHz..I feel stupid asking this ..but I was unable to find out ....
    Apr 2017
    646
    It is 44.1k, you can find it here: https://github.com/PaulStoffregen/co.../AudioStream.h
     #define AUDIO_SAMPLE_RATE_EXACT 44100.0f
    22,775
    Yup. Teensy 4.x has a dedicated PLL with high resolution config, so it can create exactly 44.1 kHz.
    The older Teensy 3.x board ran at 44.117647 kHz (or actually 48 MHz / 1088) because they lack a PLL for audio, so they're limited to creating the audio clock by integer division of the various system clocks.
    Apr 2020
    66
    Thank you very much ..I was getting confused across models ..what does the teesy 4 default to naturally if you don't define it ? ?.and question #2 ..does changing the above parameter allow you to step up the sampling rate to say 48k or 96k ?
    22,775
    Default is 44.1 kHz.
    If you change that define, most of the library will adapt. But some parts, especially USB and WAV file playing, have other dependency on 44100 Hz which that define doesn't change.
    Apr 2020
    66
    Thanks for the info ...I appreciate the response.?now to go and fix my filters ..lol
Tags for this Thread
