/Applications/Teensyduino.app/Contents/Java/arduino-builder -dump-prefs -logger=machine -hardware /Applications/Teensyduino.app/Contents/Java/hardware -hardware /Users/mos6502/Library/Arduino15/packages -hardware /Users/mos6502/Documents/Arduino/hardware -tools /Applications/Teensyduino.app/Contents/Java/tools-builder -tools /Applications/Teensyduino.app/Contents/Java/hardware/tools/avr -tools /Users/mos6502/Library/Arduino15/packages -built-in-libraries /Applications/Teensyduino.app/Contents/Java/libraries -libraries /Users/mos6502/Documents/Arduino/libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10813 -build-path /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008 -warnings=none -build-cache /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_cache_6432 -verbose /Users/mos6502/Documents/Arduino/overthink.exe/LibraryTest/SD_Teensyduino/SD_Teensyduino.ino
/Applications/Teensyduino.app/Contents/Java/arduino-builder -compile -logger=machine -hardware /Applications/Teensyduino.app/Contents/Java/hardware -hardware /Users/mos6502/Library/Arduino15/packages -hardware /Users/mos6502/Documents/Arduino/hardware -tools /Applications/Teensyduino.app/Contents/Java/tools-builder -tools /Applications/Teensyduino.app/Contents/Java/hardware/tools/avr -tools /Users/mos6502/Library/Arduino15/packages -built-in-libraries /Applications/Teensyduino.app/Contents/Java/libraries -libraries /Users/mos6502/Documents/Arduino/libraries -fqbn=teensy:avr:teensy41:usb=serial,speed=600,opt=o2std,keys=en-us -ide-version=10813 -build-path /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008 -warnings=none -build-cache /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_cache_6432 -verbose /Users/mos6502/Documents/Arduino/overthink.exe/LibraryTest/SD_Teensyduino/SD_Teensyduino.ino
Using board 'teensy41' from platform in folder: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr
Using core 'teensy4' from platform in folder: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr
Detecting libraries used...
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/sketch/SD_Teensyduino.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SD.h: [SD@1.2.4 SD@1.2.2]
ResolveLibrary(SD.h)
-> candidates: [SD@1.2.4 SD@1.2.2]
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/sketch/SD_Teensyduino.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/sketch/SD_Teensyduino.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/File.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/SD.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/cache_t3.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/card_t3.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/dir_t3.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/fat_t3.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/file_t3.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/init_t3.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/NXP_SDHC.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/Sd2Card.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/SdFile.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD/utility/SdVolume.cpp
Using cached library dependencies for file: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI/SPI.cpp
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/sketch/SD_Teensyduino.ino.cpp -o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/preproc/ctags_target_for_gcc_minus_e.cpp -DARDUINO_LIB_DISCOVERY_PHASE
/Applications/Teensyduino.app/Contents/Java/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/precompile_helper /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008 /Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -x c++-header -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/pch/Arduino.h -o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/pch/Arduino.h.gch
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/pch/Arduino.h.gch
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-g++ -c -O2 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++14 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=153 -DARDUINO=10813 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH -I/var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/pch -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4 -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD -I/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/sketch/SD_Teensyduino.ino.cpp -o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/sketch/SD_Teensyduino.ino.cpp.o
Compiling libraries...
Compiling library "SD"
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/dir_t3.cpp.o
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/cache_t3.cpp.o
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/fat_t3.cpp.o
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/SD.cpp.o
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/File.cpp.o
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/init_t3.cpp.o
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/file_t3.cpp.o
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/card_t3.cpp.o
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/utility/NXP_SDHC.cpp.o
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/utility/Sd2Card.cpp.o
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/utility/SdFile.cpp.o
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/utility/SdVolume.cpp.o
Compiling library "SPI"
Using previously compiled file: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SPI/SPI.cpp.o
Compiling core...
Using precompiled core: /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_cache_6432/core/core_5a344d82694cbc94f2b0e86b18501051.a
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-gcc -O2 -Wl,--gc-sections,--relax -T/Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/cores/teensy4/imxrt1062_t41.ld -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/SD_Teensyduino.ino.elf /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/sketch/SD_Teensyduino.ino.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/File.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/SD.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/cache_t3.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/card_t3.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/dir_t3.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/fat_t3.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/file_t3.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/init_t3.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/utility/NXP_SDHC.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/utility/Sd2Card.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/utility/SdFile.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SD/utility/SdVolume.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/libraries/SPI/SPI.cpp.o /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/../arduino_cache_6432/core/core_5a344d82694cbc94f2b0e86b18501051.a -L/var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008 -larm_cortexM7lfsp_math -lm -lstdc++
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/SD_Teensyduino.ino.elf /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/SD_Teensyduino.ino.eep
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/SD_Teensyduino.ino.elf /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/SD_Teensyduino.ino.hex
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/stdout_redirect /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/SD_Teensyduino.ino.lst /Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objdump -d -S -C /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/SD_Teensyduino.ino.elf
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/stdout_redirect /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/SD_Teensyduino.ino.sym /Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-objdump -t -C /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/SD_Teensyduino.ino.elf
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/teensy_post_compile -file=SD_Teensyduino.ino -path=/var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008 -tools=/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/ -board=TEENSY41
Used: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
Not used: /Applications/Teensyduino.app/Contents/Java/libraries/SD
Using library SD at version 1.2.2 in folder: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SD
Using library SPI at version 1.0 in folder: /Applications/Teensyduino.app/Contents/Java/hardware/teensy/avr/libraries/SPI
/Applications/Teensyduino.app/Contents/Java/hardware/teensy/../tools/arm/bin/arm-none-eabi-size -A /var/folders/rw/534kw6kd6hs6chfgmjmjv79r0000gn/T/arduino_build_330008/SD_Teensyduino.ino.elf
Sketch uses 23856 bytes (0%) of program storage space. Maximum is 8126464 bytes.
Global variables use 45756 bytes (8%) of dynamic memory, leaving 478532 bytes for local variables. Maximum is 524288 bytes.
Invalid library found in /Users/mos6502/Documents/Arduino/libraries/i2cdevlib-master: no headers files (.h) found in /Users/mos6502/Documents/Arduino/libraries/i2cdevlib-master
Invalid library found in /Users/mos6502/Documents/Arduino/libraries/Adafruit_nRF52_Arduino-master: no headers files (.h) found in /Users/mos6502/Documents/Arduino/libraries/Adafruit_nRF52_Arduino-master
