delay of nanosecond Teensy ?
aybiki
is it so possible to make a delay of nanosecond between a low and high state with a teensy 3.6 seen that its frequency 180 MHZ ?
I don't think the pin drivers can go that fast even if given a 500MHz signal... Typical external CMOS pins have rise- and fall- times of a few ns.
For faster you need impedance matched LVDS or similar - this is into the microwave frequency domain, everything needs to be a transmission
line.
experimentally with the microsecond delay function I can go down to 7 microseconds after remaining constant!
